Question about Frigidaire FEB27S5A Electric Single Oven
Electric wall oven will not heat up
All of my controls work and they appear to function in response to my pushing buttons BUT I have no heat in my oven. It will not heat or broil although the red indicator bar does show up on the control screen.
  • ovenmad Dec 26, 2007
    I'm having the same problem. Everything seems to work, except no heat from elements. I suspect the oven temperature probe is out of wack. We used an oven cleaner then noticed on the can it said not to use it in a convection oven. Perhaps that screwed something up.
This is ovenmad from the previous post. I had a repair guy come out and he found the problem to be the Safety Thermostat. When tripped, this allows everything to work on the oven except the elements. He did not have the part with him so will return in 6 days to replace it. That should solve the problem. No idea why it tripped. The safety thermostat is located on the rear of the oven so we will have to pull out the oven to replace the thermostat. Again, this was a Frigidaire Single Electric Wall Oven made in 2004. Hope this helps somebody else.
Posted on Dec 29, 2007
  • 3 Answers
My Frigidare/Electrolux Single Wall Oven (PLEB30S8CCB, made in 2003) had both regular and broiler elements fail to heat after a self-cleaning cycle. The problem was the Safety Thermostat (part #318004900), but note that that part has a red Reset button. I pulled the oven from the wall and for my model the Safety Thermostat was on top of the oven about 12 inches from the front under the metal shielding that covers the whole top of the oven. I pushed the Reset button and heard a click. The oven seems to work fine so far, but I have not tried another cleaning cycle.
Posted on Mar 19, 2012
I just had the same problum happen to my wall oven and i took it out of the wall and the wire was burnt that goes to the heating element....now my oven works awsome.
Posted on Jul 26, 2008
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: OVEN DOESN'T GET HOT
You probably have a faulty element if it is a fan oven
Posted on Nov 18, 2008
I have a GE Monogram Built-in Convection Wall Oven (model no. ZEK737WP3WG) and the heating elements have stopped working. The electrical power is working, and the control panel, light, convection fan...
It is possible that a relay on the control board is bad. GE has a relay in the common circuit to the bake and broil element. this has been a problem in a few ovens I have repaired. Check for this it is usually an orange relay on the board.
Apr 27, 2014 | GE Ovens
I have a Magtag wall oven MEW6530DDS model. The panel buttons do not work. I've had the oven about 3 yrs. Do I need to replace the control panel or control board?
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Sep 18, 2010 | Maytag 30" Built-In Single Electric Wall...
Oven will not work ,control buttons beep when pushed,oven lights work
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 14, 2010 | Whirlpool RBD275PD Electric Double Oven
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Nov 18, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire FEB27S5A Electric Single Oven Logo
980 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
