Question about Euro-Pro Steam Generator EP8001 Iron
Started to make a funny noise when you first switch on, now trips out electric
  • 244 Answers
Unplug and toss. replace. has a short somewhere in unit. better safe than sorry!! if still under warranty- get it replaced!
good luck- stay safe!
Posted on Oct 04, 2009
Rotary iron kenwood used
If there are wires connected to the foot pedal, control is electrical, not mechanical. Contact eBay directly for resolution.
May 09, 2017 | Irons
Electric Iron not Heating Up or not Working Right
If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter.
on Jul 14, 2010 | Irons
Son hit knob in with ironing board now can't use as if touch it it trips all electrics
There is a short in the switch where the two leads are making contact. If you take this apart you should find where this is happening and be able to fix this. You may need a new switch which should be very findable.
Feb 20, 2015 | Irons
I have a power strip that keeps tripping its safety switch even though only one electric oven is plugged into it. What do I need to do?
did you try to plug directly in to a plug ?
maby your strip is defective or has a 10 amp overload protector this will trip with heating devices of your nature.
Oct 20, 2013 | Rowenta DG-980 Iron
Singer professional 5 completly quit
The air conditioner should be plugged into a dedicated line, not shared. The serger may have failed because of this.
Jul 18, 2013 | Singer 14T968DC - Professional 5 Serger
Iron works for a little then electricity trips. why would this happen
You have a faulty and possibly a dangerous appliance. It could be a faulty/worn electrical cord. i suggest you get it checked out or throw it out and buy a new iron.
Dec 12, 2012 | Irons
My tefal iron tripps out fuse whenever i turn it on
check the wires that lead from wall socket to your iron it might have opened and twisted which could have created short curcuit
Aug 30, 2012 | Tefal Irons
The relay in the circuit board is probly fried together.Can be replaced but care should be taken and cord unplugged when working on the unit.
Aug 06, 2011 | Philips Irons
My rowenta iron tripped the switch after I descaled it.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Sep 29, 2009 | Rowenta Precision DM580 Iron
General electric light 'n' easy iron tripping safety switch
it is shorting out and tripping the breaker either from moisture or problem insulation
the cost to repair is more than a new iron so junk it and be safe
Jul 12, 2017 | Irons
Euro-Pro Steam Generator EP8001 Iron Logo
82 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
