Question about Whirlpool Washing Machines
FE error is displayed in my whirlpool washing machine what to do?
FE error is displayed, what to do?
  • 234 Answers
How do you know this is a generic problem for all whirpool washers?
What I can tell you is: ever since electronic controls were placed with appliances (dishwhrs, dryrs, wshrs, frigs,etc) there was this new age of error and fault codes that would lock-up the electronics. I always recommend people buy the mechanical control appliances because you do not have these interim problems. Mechanics justs keep ungoing, and if it will fail some day, you usually have a warning period, and it is more likely to be cheaper to repair than electronic controls.
Aside from all that, your owners manual should have a section in the rear that says trouble shooting; this usually has some of the standard error/fault codes and it can tell you what it stands for. Most errors can be eliminated by unplugging this electric cord and waiting 1 minute for the ciruit board to reset itself. The usual causes are: out of balance load that shook the machine too much, an overfill of water level, and overload of too much heavy close that caused the machine to strain the engine, or a short temporary power interuption while the machine was operating. Try the plug rest method and pay better attention to the load/overload. Hope all will be good. Macgivor
Posted on Oct 04, 2009
4 Suggested Answers
  • 6277 Answers
SOURCE: getting FE error on our
I suspect that stands for 'Filter Error' so I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 19, 2011
Testimonial: "I can only say a big Thank You for your kind help and prompt assiistance..it s a flter problem and cleared it off..back to working..Thanks a ton John."
  • 6277 Answers
SOURCE: My whirlpool 6th sense washing
Whirlpool's 'FE' stands for 'Filter Error'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
John C
Posted on Aug 19, 2011
  • 2468 Answers
SOURCE: we have a Whirlpool 7
either your water supply is shut off or the water fill solenoid valve isnt working to let water past the fill valve or the solenoids are not getting power from the control unit to do so
Posted on Sep 29, 2010
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My LG model WM1812CW washing machine is leaking water and says FE in the display
    problem with the inlet valve or oppressor switch,because of the overfilling water, sawing FE ERROR
    Jan 26, 2014 | LG Washing Machines
    Fe warning light
    Fe error code means "Water Overflow Error". Check the upper level sensor of the machine.
    Dec 22, 2013 | LG Washing Machines
    In display shown FE
    "FE" error code - over flow error
    -Check water conection
    -Check Water valve for proper operation
    When the "FE" error code is displayed the drain pump will be turned on to pump the water out of the washing machine. LG Washing Machine Error Codes
    This error code comes up when there is a over flow condition. The error is coming up because a part inside the washer has failed. I suspect the water valve on the back may be the culprit, it's fairly common.
    Hope helps.
    Aug 10, 2011 | Washing Machines
    The washing machine displays FE which says a faulty valve can I buy the valve and change it myself
    FE is a error signal during fill.For this problem you need to check the water in the tap.If you do this means you can use your washing machine for long time.This can be fixed by you.If your happy with my answer rate me.Thanks for your question.
    Jun 22, 2011 | LG Washing Machines
    We have a Whirlpool 7 KG fully Automatic washing and the display is showing FE and the water is not filling in the Machine
    Sep 29, 2010 | Whirlpool Washing Machines
    Whirlpool white magic h65 model.what is LE. AFTER
    LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
    Nov 05, 2009 | Whirlpool Washing Machines
    WASHING MACHINE DOES NOT GO ON
    Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
    Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
    LG TROMM WM1814CW won't stop filling. Says
    Over flow error
    Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
    Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
    Jul 12, 2009 | LG Washing Machines
    LG Sense Clean DD error code "FE" front loader washer/dryer combo
    my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
    Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
    Washing Machines Logo
    5,406 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
