Question about Welding Tools
Trying to find a manual for a Pro Arc 1150B 115 volt/100 amp welder - can you help?
    Problem Solver:
  • 7 Answers
Go to proarcwelding.com . I didn't see a manual available,but they have a contact page. If anyone can get you one ,they should.
Posted on Oct 13, 2009
Spool won't turn
are the rollers tightened enough, also maybe the wire is jammed in gun.
Feb 02, 2013 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Trying to find out what year and information on a hobort welder i thing model # ml604 serial# 3dw-9287 specs 1684 I think this is the right information Thank you
Can't help you with the year,but here's the owner's manual. The serial number should be a combination of two letter and six numbers, like: KK123456. The one you are posting it's not a serial number.
http://www.hobartwelders.com/om/0900/o947h_hob.pdf
Hope this help you. ; ).
Mar 07, 2011 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Where can i get parts for my hobart welding machine but is a old welder
Your local welding shop supply will be able to give you advice, the guys at Lowes and farm supply shops just sell the welders
Oct 05, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
I bought a 20 amp arc welding kit from canadian tire and dont have an instruction manual with it. i have given it the proper electrical current and amperage and still cant get it too work. looking for the...
20 amps seems like a fairly feeble arc welder--most light models run up toward 80 to 100 amps for a stick welder with wire feed models somewhat lower. Even accidently touching the two leads together should have produced some arcing. You may have a defective unit. Hope this helps!
Aug 16, 2010 | Garden
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
My wire dont feed out some time when i pull the triger
Inside your machine just in front of the wire spool is an adjustment to increase the tension on the wire tighten it a little bit at a time until your wire feeds
Feb 05, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
My fm140a will not feed wire
You may need to adjust the tension just in front of the wire spool
Your gun liner maybe shot
Dec 28, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Curcit breaker triping
chances being this welder is probaby 30 amp. rated and you probably have amp. service at a lower rating change your breakers to 30 amp. or higher or you fuses i do hope this will help you,thank you.
Dec 23, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Wire feed motor not working
I believe the circuit card assembly has failed. It is very rare that the motor is the problem.
Sep 30, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Welding Tools Logo
821 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
