Philips rear projection TV component identification, what is it
Inside the Philips rear projection TV, there is a component that has six coloured knobs. the component connects to the three projection bulbs, and the knobs are the same colour as each bulb. Do the coloured knobs adjust the bulb convergence, brightness, settings etc. ?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
They adjust FOCUS and Screen settings---they have nothing to do with convergence---if you have not touched them---do not---they are not real easy to reset correctly.
What is wrong with the set and what is the model number?
let me know and I will try to assist you
SD TECH
Posted on Oct 04, 2009
Hi! I have a philips rear projection tv but the colour on the tv is not looking right. It has like a green and some times you can see blue and red lines running down. Can someone please tell me what...
if the lines are scrolling up or down the screen slowly then you have a power supply fault, this fault is likely due to a defective filter capacitor and as time goes on it will get worse, have this repaired before it causes damage, if you are thinking of tackling this problem your self read on....
Hello, i will list the criteria required to service TV and projector TV`s first and foremost you require a good understanding of how TV`s work and the ability of reading schematic diagrams, then you require a knowledge of how printed circuit boards are patterned so you can navigate around them to locate possible trouble spots.
then you require
1 multi meter of good quality
1 oscilloscope 20 MHz or better
1 shop service manual pertinent to your type and model of unit you wish to repair
this is a minimum requirement of test equipment you can have
you also kneed a location or locations to obtain the replacement parts you may require to complete the service task.
Now if you have all the above criteria in place then you have some hope to service your unit
Warning rear projection televisions can harbor in excess of 30,000 ,yes that is thousand Volts
There are and never will be user serviceable components inside LOL
Now if you are ready and require further assistance you may contact me and i will step you through the diagnostic procedures Good luck
Mar 01, 2011 | Philips 55P8341 55" Rear Projection...
Tv picture settings for rear projector tv want colour settings for my tv
If you cannot align RED, BLUE, or Green your TV has a convergence failure. You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Philips 43PP9202 43" Rear Projection...
How do I remove the speaker cover from my Philips 60pp9701 rear projection tv?
you need to open rear case, and check inside on bottom part case. is normaly inside of plastic case or wood
Feb 12, 2010 | Philips Magnavox 60PP9701 60" Rear...
How to make the picture to a Philips 2002 rear projectiontv clear
needs to replace the liquid in the tubes of blue and green projection
Jan 06, 2010 | Philips 55PW9363 55" Rear Projection...
Colour convergence on a projection TV
hello it sound like convergance chips may be the problem
shaun
May 11, 2009 | Philips 43P8341 43" Rear Projection...
Philips 43PP925 rear view television
Can you describe what you mean by "funny with colour" please? That will help to determine the problem circuit.
Thanks,
Dan
May 23, 2008 | Philips 43P8341 43" Rear Projection...
Akai tv has failed to work
There are many circuit areas inside a TV set that can have burning components. Since you describe a colour change, I would think the fault may be in the video processor, screen biasing, or video drive path.
Jerry G.
May 22, 2008 | Akai PT4799HD Rear Projection Television
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
Blinking power light
General IIC error. An experienced technician will have to repairthat problem, as you need specialized equipment.
Apr 12, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
Electro Med Services...
