Question about Plumbing
Will a compression fitting work on 1/2'' galv. pipe?
I will be doing a little plumbing job that I am worried about. The plumbing was put in aroung 1920 and it is 1/2'' galvanized pipe. Going to try to remove from the end of a line a fitting and connect in with PEX. My fear is when I remove the fitting the threads will peal off and I will have to go to the next joint and have the same thing happen again. If the threads do peal off is there a connection that I can make in the middle of a nipple that does not require the use of threads? I was wondering if a compression fitting will work??
    Problem Solver:
  • 5 Answers
The best way is to just keep peeling back untill u get a decent joint to goto per, either by using an mip in a fitting or by using an fip on the end of the treaded pipe
Posted on Dec 01, 2012
  • cmartineau
    cmartineau Dec 01, 2012
    *pex not per
  • 129 Answers
They do make a compression coupling for galvanized pipe, but I don't trust them very much. When you unscrew the joint with a pipe wrench just make sure to back it up with another, so you don't start to unscrew the next joint back.
Posted on Oct 04, 2009
Sharkbite fittings are not designed for galvanized pipe. They are designed for copper, pex and cpvc gauge pipe. Try to only cut the galvanized pipe with a hacksaw or a pipe cutter ( with wheels). A power tool such as a reciprocating saw will vibrate the rest of the plumbing and cause future leaks. You can go to the next fitting and install a male thread by compression type transition fitting. It is very important to counter hold any galvanized fitting to prevent any movement that may leak.
Posted on Oct 14, 2009
  • 24 Answers
I'm a big fan of the SharkBite push fittings-- now if you are doing work behind a wall most tradesmen will not recommend using one of these because they have not been tested over extended periods of time-- however from my experience they work great and could not be easier to use!
Here's a site: http://www.pexsupply.com/SharkBite-Fittings-595000
Posted on Oct 09, 2009
I am making a plumbing repair to copper pipe. There is a small trickle of water that I cannot stop flowing. What is a good way to block the water to make a good joint?
Jamb a piece of white bread(wadded into a tight ball)into the pipe. Work fast. Bread will stop flow for a bit, but will breakdown quickly under pressure and dissolve with no blockage.
May 04, 2017 | Plumbing
What part do I need if I live in Israel and bought a kitchen faucet from USA. Both says 3/8, but is seems that one of these called FIP and one called "Compression". Can't tell which is what...
3/8" =9.5mm so you will need compression olives that are 9.5mm dia or to suit 9.5mm pipe
the metric pipe size will be 10mm so you need olives to get from 3/8 " to 10mm
as you can see there is only a slight difference but 3/8 fittings will be too tight
you will need the olives and the nut to complete the change over
with plumbing , the thread is standard bsp so there should be no problem getting the nut ( if it fits the pipe ) to screw onto the fittings
Sep 07, 2017 | Plumbing
How do I seal a copper pipe connecter.
The tubing end must be square in order to seat properly in the fixture. The old compression ring may be distorted. The nut may have been cross-threaded at some point. The ultimate solution may be to remove the old fitting and start over with a new one.
May 12, 2014 | Plumbing
How to change from a 1 1/2 pipe to a 2 pipe under a sink
go to a plumbing supply store and ask for a 2" by 1 1/2 pvc bushing
Sep 02, 2012 | Mountain Plumbing Products PVC Pipe Deluxe...
I want to put another water line onto an existing 3/4 galv. pipe. To put a "T" in the middle will I have to weld it or is there left and right threads so you can tighten the middle pipe turning in one...
The problem you are faced with is that galvanized pipe is put together as a "progressive" process. The easiest action you can take is to cut the galvanized pipe where you want the T and back out both pieces of pipe from their respective joints. Reassemble and use a union coupling to finish the connections. An alternative would be to replace the section of the line where you want the T to be with copper pipe, using a dielectric union at both ends where you connect back into the galv. pipe. You have to solder the connections, but it might be easier.
Sep 12, 2010 | Plumbing
I need to replace a brasscraft compression valve G2CR19X C1 how do I remove the brass fitting and nut that goes around the plastic hose that comes out of the wall and plugs into the toilet.
usually if its leaking and you have the same replacement then just reuse the compression nut and furrow and it doesn't hurt to use a little pipe dope or just unscrew the packing nut and change out the the valve stem
Sep 11, 2010 | Timemist 383081TM01 Plumbing Replacement...
2005 KIA Rio fuel pump is out is there a special tool for the compression ring or do i need to drop the tank and hammer it out
the fuel pump on these should be a plate with about 6 screws (just under the rear seat by the way), the fuel pump "module"(entire assembly),and the o ring. i dont remember any special tools i used. should be pretty straight forward and when you put it in it will want to stay up. dont worry, they are spring loaded. just simply put the screws in and snug a little at a time going aroung the circle a few times.
Nov 03, 2009 | 2005 Kia Rio
I have a older home with very slow hot water flow. Is there anything I can do myself? The pipes are cast iron.
Have you tried removing the aerators from the faucets and cleaning out the sediment. You can also drain down the water tank to try and remove any sediment that has settled in the bottom.
Sep 21, 2009 | Plumbing
Installation of shut off valves
First shut off the main water supply. This is likely located close to your water meter where the main water supply enters your house. After shutting the water off, open a faucet on the lower level and let the water lines drain. Disconnect the water supply line running to the base of the fixture you will be working on. On some, this will just be a screw on connection, and on others it may be a soldered pipe. If it's soldered, use a hacksaw (or better yet, a pipe cutter) to cut the pipe in two places, about 2" down from the base of the fixture and also 6" to 10" further down the pipe. Use the reamer on the pipe cutter to remove any burrs on the copper pipes, and then clean them (with a piece of sandpaper or emery cloth) until they shine. Slide the compression nut from the shut off valve onto the pipe with the threads facing the open end. Then slide on the compression ring. Wrap the pipe with Teflon tape or spread plumbing joint compound on the end of the pipe, and then push the shutoff onto the end of the pipe. Slide the compression nut and ring up to the shut off valve and hand tighten the nut. Attach the compression fitting of the flexible supply tube to the other side of the shut off valve and hand tighten it as well. Attach the compression fitting on the supply tube to the base of the faucet and hand tighten it. Once all your compression fittings are attached and hand tightened, use an adjustable wrench to tighten them all firmly. Be careful you don't over tighten as this can bend the soft copper pipe out of round or damage a compression fitting. Turn the water back on and check for leaks. (Don't forget to open the shut off valve when you turn on the faucet.)
Aug 27, 2008 | Moen Chateau, Two-Handle Garden Tub Faucet...
Plumbing Logo
1,036 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
