Question about Shuttle XPC (ss56g) Barebone
What kind of ram chip can i use for this system?
I want to add the bytes of my ram.what ddr ram or chipboard can i use for this system?
  • 11,800 Answers
Any DDR400 with less than 1GB. Beware, it can only support just 2 bars so if they are already occupied you must remove them both and replace with another 2 . And don't buy bars bigger than 1GB or it will not work, at all.
Posted on Oct 04, 2009
What ram for
RAM is a type of computer memory accessed randomly during hard drive processes.
A computer's RAM is considered "random" because any byte of memory can be accessed without processing previous bytes.
Purpose of RAM
RAM is used to load and run programs or applications on a computer's operating system. More RAM means more applications and programs can be run simultaneously.
SRAM
Static Random Access Memory, or SRAM, stores data on a computer in a static method, meaning the data stays the same with power being supplied to the memory chip. SRAM is the faster RAM when compared with DRAM.
DRAM
Dynamic Random Access Memory, or DRAM, is a type of memory used in personal home computers. This type of memory must have an electrical current to refresh. DRAM is used more commonly because it's less expensive to manufacturer and install in chips.
EDO RAM
Extended Data Output, or EDO, is a new type of DRAM chip that uses technology to add 10 to 15 percent more speed than normal. A computer that uses EDO technology must meet the chip requirements or the EDO will not be recognized.
FPM
Fast Page Mode, or FPM, is a RAM speed enhancement that uses rows of bits selected in columns and rows of the memory.
FPM is used in EDO RAM.
Nov 02, 2012 | Computers & Internet
Add more ram
hi-
To add ram - look on the back of the lap top. You will see some screws that are holding down a little door. There may be two of these. Remove the screws on the ram cover and remove ram cover
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ram slots are stacked. you have to remove the top one first.
1- press the buttons on the sides of the ram chip, and then it will pop up and towards you.
2- 2- pull this ram upwards and out
3- from there, you can take out the other chip, if there is one, or you can start installing.
4- installing the new ram chips is just as easy
5- line up the slots in the chip, then push it in as far as you can without breaking it.
6- then push it down so that you hear it click on both sides, and doesn't budge.
7- Repeat using the top chip.
This should do it –
I hope it helps- please rate me – thanks
G
Mar 18, 2010 | Acer Aspire 9500 Notebook
I was wanting to know if updating the bios will all me to add more ram then my computer allows which is 1g
Your PC can support 2GB as it is. That is 1GB per Slot and there are two slots. Your Standard type of RAM to use would be DDR PC2700,DDR PC3200 1GB.
However even though you could install 2x 2GB Chips it is not recommened by manufacturer specifications and I suggest you don't buy these Chips until you could test it first, making sure sure you run the computer for a few hours and opening resource intensive programs like high end games and a few other programs or anything really at the same time, which would need a considerable amount of RAM so you can test system stability.
Mar 01, 2010 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Problem for ecs m810d
it's between ddram n sdram connector.
Apr 03, 2009 | PC Chips M810DLU (M810DLUV75C) Motherboard
PC RAM
This refers to the data width and chip configuration. 64*8 is an 8 chip 512MB module. (8 components @ 64MB each) 32*8 is an 8-chip 256MB module. (8 components @ 32MB each), etc.
Mar 03, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
Memory
According to your motherboard specs.
2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR400/333/266) ecs_buttom_03.gif Maximum: 2GBYou can use up to PC3200 that's the fastest speed it will read...
Feb 03, 2009 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Which memory ram for amilo pro v7010
http://www.fujitsu-siemens.ru/Resources/123/2080773523.pdf
Here's a link to the Data Sheet with the specifications to that Laptop in Adobe Reader format.
Looks like your Laptop came with either 256 or 512 MB of DDR SDRAM and it is upgradable to 2 GB of DDR SDRAM.
You can check to see exactly how much RAM your computer came with by going to Control Panel, double-click System and it should tell you how much RAM you currently have in the System Properties box.
The motherboard has 2 slots for RAM, you you could add a second 256 MB or a second 512 MB stick of RAM. Or if you wanted to upgrade to the 2GB of maximum RAM this computer handles, then you can take out the RAM chip(s) that is installed and install two 1G DDR SDRAM.
Jan 31, 2009 | Computers & Internet
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Pc will not boot
Make sure the ram is seated properly and in the slots correctly. If you are using more than one chip, use only one to start and then add any others yoiu may have. I think you will find a ram slot is craked or the chip is inserted backwards. You really cannot damage a M/B by adding DDR instead of DDR2. It really just about the bus path and bus speed. Double check our work.
Sep 26, 2008 | Biostar K8M800 Micro AM2 Motherboard
I have a compaq with a 90 gig hard drive, at presenr I am running 384 bytes of RAM. How much will this PC safely handle?
Depends! The amount of RAM has nothing to do with capacity of the hard drive. If your motherboard is a P3, it probably has to memory slots that will handle 256mb each (512 total). It sounds like you have a 128mm chip and a 256mb chip installed now. I won't even attempt to run XP with less than 256mb of RAM. You can run XP with 128mb, but not very well. With Windows XP SP2, you will have to have at least 256MB. Most P4 or newer computers use DDR RAM wich can be bought at larger capacity (ie 1000MB).
Apr 18, 2008 | Computers & Internet
Shuttle XPC (ss56g) Barebone Logo
50 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
