Turbo c++ not running in dosbox.........because libraries were not found in it
  • 117 Answers
Go to your turbo C++ compiler , choose options -> Directories and check if your library and include directories are assigned their actual positions
Posted on Oct 04, 2009
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
1. How to install and run turbo C++ 4.5 on Windows 7 (32)? 2. How to run Turbo C++ 3 on Windows 7 in full-screen mode?
I had similar issues with an old version of Turbo Pascal.
I used a program called DOSBox which emulates the older machines the packages were designed for.
http://www.dosbox.com/
It worked very well including full screen.
Feb 23, 2011 | Borland Turbo C++ 4.5 Full Version for PC
I want to install Turbo c++ in windows 7 64 bit
Do you have dosbox on windows 7? If yes, then u can download turbo c++ and run it through dosbox.. let me know if you need the exact steps..
Jan 03, 2011 | Computers & Internet
How to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
Plz tell me how i can run c++ in full screen in vista ultimate
Hello
Use the command prompt. Maximize the window size. Change directory to c:. You will have a line that fits 75 characters and a window that occupies about 2/3 of the whole window. That's enough fore all reasonable problems. If you are not happy with what you get, you may try developping your C++ program under Linux.
Hope it helps
Aug 29, 2009 | Compaq Presario 700 470024-192 Notebook
Problem for installing turboc++4.5 in wista
ok man i too had teh same prob dont back to xp
Before going to the details u have to create a folder (any name will do). Here we name it as Turbo
Now , Type in the following commands after the Z prompt:
Now type d: to shift to d: prompt .
D: cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
D: cd Bin
D: TC or Tc.exe [This presents u the Turbo C++3.0 screen]
On the Turbo C++ goto Options>Directories>Change the source of TC to the source directory [D] ( i.e. virtual D: refers to original c:\Turbo\ . So make the path change to something like D:\TC\include and D:\TC\lib respectively )
In order to get the full screen use the key combination of Alt and Enter
When u exit from the DosBox [precisely when u unmount the virtual drive where Turbo C++ 3.0 has been mounted] all the files u have saved or made changes in Turbo C++ 3.0 will be copied into the source directory(The directory which contains TC folder)
It is a good idea to backup your files in the source directory prior to running DOSBox 0.72
For additional help go through the readme file located in the installation folder or look on the website of the DOSBox forum.
The above procedure has been successfully implemented on Windows Vista Ultimate 64 bit
IMP : Don't use shortcut keys to perform operations in TC because they might be a shortuct key for DOSBOX also . Eg : Ctrl+F9 will exit DOSBOX rather running the code .
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
I too have a problem on my PC,when running the Turbo C programThe error message is:
16 bit MS Dos Sub system
turbo c++ IDE the NTVDM has encountered an illegal instruction.
At last i found the solution, and it is simple.
After installing your turboC follow the steps..
1) go to TC directory and open BIN.
2)In "BIN" folder you can find "tc.exe". Right click on "tc.exe" and click properties (and make sure that do not click on shortcut of TC.exe).
3)In properties there should be a tab called "screen", In that you will find "usage" option. There.. select "window" option instead of "full screen".
4) Then click "OK".
5) Now click "TC.exe".
6) It will open in window mode, if you want you can change full screen mode by pressing "ALT + Enter".
Thanks & Regards
Shravan reddy Konnela.
Jun 02, 2009 | Microsoft Windows XP Professional with...
Cant run turbo c++ with dosbox in vista
Hi , Use This Commands in DosBox : Mount C C:\TC
in DosBox run Tc and go to Option Menu\Directories
replace all paths with this : C:\INCLUDE
C:\LIB
then your Libraries will be found !!
Apr 25, 2009 | Microsoft Windows® Vista 64-bit Business...
I have a hp laptop with windows vista home premium.i want to work on turboc++, but i am unable to do so. kindly giv your assistance.....
Install the software DOSBox ver 0.72 ( 1.2 MB ) (Freeware) from the link below.
http://prdownloads.sourceforge.net/dosbox/DOSBox0.72-win32-installer.exe?download
D: cd Bin
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
Does Vista Support Turbo C/C++??
google vista + turbo c.... you need a program called dosbox and it's a very lenghty explanation but it is possible to do
Aug 25, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
David Payne
David Payne
