Question about Bosch Classixx WFL 2066 Front Load Washer
WATER WIIL NOT DRAIN - Bosch Classixx WFL 2066 Front Load Washer
    Sergeant:
  • 228 Answers
Will need either a new drain pump or blockage stopping impellor turning if you can remove filter you should see if theres a blockage in there probably a coin or hair grip thats what i usually discover.
Posted on Oct 20, 2009
Wiil not drain
Pump must be frozen. It should be directly under the machine, try to turn it with pliers.
Apr 15, 2014 | KitchenAid Dishwashers
Water leaking under hood
yup check the radiator hoses upper & lower, when the water pump goes bad also leak out coolant or water ect and the final wiil be an internal head gasket leak i hope this work for you.
Jul 13, 2012 | 2000 Hyundai Sonata
I think i have a frozen drain tube. water is leaking from the freezer into the refrigerator. i can not find the drain tube. can you tell me where it (the drain tube) is located and how i can access it. ...
Yes you can get to it from the inside. There should be screws in the back towards the bottom of the freezer that wiil let you remove the bottom of the freezer compartment. Under tere you will see the drain hole and the freezer coils, alond with the defrost coil.
Then checkout this tip to help you make it so the hole won't freeze shut again...
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Apr 22, 2010 | Whirlpool ET1FTKXK Top Freezer...
Water is leaking inside the refrigerator.
heatman101
Apr 22, 2010 | Refrigerators
How do you get at the tube that drains water from the freezer to the pans on the bottom...mine is clogged and water drips into refrig compartment. whirlpool ET1MHKXMT01
heatman101
Apr 17, 2010 | Refrigerators
WASHER WIIL STOP EARLY AND WILL NOT SPIN OUT WATER THE CLOTHES ARE STILL WET WHEN I CHECK THEM AND THE LIGHT IS USUALLY BLINKING I TRIED CLEANING OUT THE LOWER FILTER AND THAT DID NOT FIX IT....
Be sure the drain hose is not blocked and be sure it does not have a kink in it when you slide your washer back in place. If that is not the problem, it's probably your timer. Mechanical timers have a tendency to "skip" cycles over time.
Nick
Dec 27, 2009 | Washing Machines
Wiil not pump away cleaned filter stiil wont pump away.fault oe came up on the lcd screen
the DRAIN MOTOR PUMP might require cleaning also ,located usually at bottom side where 2 hoses connected to it , good luck AJ
Nov 23, 2009 | Cameras
Washer will not drain after wash cycle
I need more information please I need the brand n seriel #.
than you
May 12, 2009 | Washing Machines
1983 glodwing will not start i put new batt in
It sound to me that you have a permanent drain. Charge the battery and put an amp meter in line and I'm guessing it will show a reading. After this remove one fuse at a time till the drain stops and you have partially indentified your problem.
Regards,
Maurice
Mar 22, 2009 | 1983 Honda GL 1100 Innerstate Gold Wing
McClary (GE) dishwasher not filling properly
replace inlet valve if your pressure is high if low remove restrictors in the centre of vale to allow quicker flow of water
Feb 20, 2008 | Dishwashers
Bosch Classixx WFL 2066 Front Load Washer Logo
171 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
