Question about Brother MFC-3240C All-In-One InkJet Printer
Brother Printer MFC 425CN
Hi, I have a problem with my printer, It says Unable to Init. See troubleshooting and routine maintenance chapter's in User's guide.
I have turned off the printer and computer for couple of hours. But it's still not working. Please give me a solution. Thank you
  • johnmila Dec 22, 2007
    Oh.. I've tried to reinstall the drivers. But it still not working. Thank you for the quick respons. But I still have the problem. Once again, thank you.
Well I'd download the software (or if you disks use them) and reinstall the drivers. There may be a corrupt file.
Also make sure that the connection is good with your usb.
also make sure in the set up that you have all the right preferences; for example you should not have LPT1 selected if you are using a USB connection.
Posted on Dec 22, 2007
  • Brother Master
  • 1,113 Answers
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys then you should be in maintence mode, then 82 set A code should display..... 41? lets hope not cause another number would be better.
  • Soulvisitor
    Soulvisitor Dec 22, 2007
    What code? Did you get to maintence mode?
  • Soulvisitor
    Not driver issue your machine has an error and we need to put it in service mode to get it to display code so we know what we are looking at, those buutons need to pressed in order and fast then arrow to 82 and press set.
Mix-it-up
  • 832 Answers
SOURCE: Unable to clean
you need a new waist ink absorber box and have to do a reset. The absorber box can be purgchased from a service partner (see brother homepage of your country). Same procedure:
http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
Posted on Mar 08, 2008
SOURCE: Printer not printing!
Some good and kind people who assisted in solving
my problem. Thank you .
Posted on Jul 17, 2008
SOURCE: [HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Posted on Oct 22, 2008
sardanadixit
  • 813 Answers
SOURCE: unable to print See Troubleshooting and routine maintenance chapt
Download the manuals from:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_5440CN_5840CN_EN_108.PDF
and
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_110C_MFC_210C_3240C_3340CN_420CN_5440CN_5840CN_620CN_EN_1266.PDF
Please rate this solution in case you find it helpful, else leave a comment and I shall revert back with more suggestions.
Posted on Aug 11, 2009
Testimonial: "Thank you for the site info! i looked for a long time, wish i had asked and followed your advice the first thing as it went right to it."
pineworks
  • 4041 Answers
SOURCE: brother mfc-7420 - unable to print
OK Try
Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the best
Posted on Jan 30, 2010
Unable to clean see troubleshooting and maintenance chapter in user,s guide
They want you to read and do what is says to do in the troubleshooting and maintenance chapter of the users guide that came with your printer.
Apr 12, 2011 | Brother MFC-425CN Multi-Function Center...
Unable to clean see troubleshooting and routine maintenance chapter in user's guide
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
Jan 30, 2011 | Brother Multi-Function Center® MFC-215C...
See Troubleshooting and routing maintenance chapter in User's Guide Init Unable 46
Init Unable 73
Jan 23, 2011 | Brother MFC 210C All-In-One InkJet Printer
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 210C with error code 4F
This will reset the purge count value. Then restart your printer and it should work just fine !
Jan 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
Dear Guru,
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
BROTHER MFC210-C "UNABLE TO INIT"
good day! Unable to print 50 means'' the machine does not work due to paper jam or some sensor...mostly unable to print 50 is sensor problem. to clear the problem clean the sensor, and then the mechanical...t
Dec 07, 2017 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-210c
You can download the manual from this link: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf See page 11-4
Aug 05, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
111 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
