Question about Acer Aspire 4520-5582 Notebook
Cd/dvd drive missing on my computer
I have reformatted my laptop in hope to get the cd/dvd drive back into the computer. but it failed, it has been missing from "my computer". I tried all the solutions i could find from the internet, including deleting upper filter, still can't work. there is no CD/DVD drive in device manager, no external removable disk drive seen on my computer. IS there any solution to it?
Please Help.
Thanks.
My laptop is Acer Aspire 4520.
  • Acer Master
  • 11,800 Answers
Enter in the BIOS and see in the boot order or the internal units if the dvd unit is still there. If it isn't then it's dead, replace it.
If it is then you didn't do a correct reinstall. Enter the bios again and make sure the dvd unit is the first in the boot order, boot from a Linux Live-CD like PCLinuxOS and from Computer Management/ Hard Disks  delete all partitions, format the entire disk to something else then format it again to NTFS or FAT. This is the only way you can be sure you are doing a clean install.
Posted on Oct 04, 2009
All drives reformatted. cd will not read anything. only outboard floppy drive will communicate with Acer 2420 How to restore
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps.
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it.
If still no joy
It might be past its use by date
Dec 07, 2012 | Acer TravelMate Computers & Internet
Dell 1525 dont maneger is dosent see in the screen how i reformat
Reformatting the hard drive of a computer is sometimes an unavoidable task. Whether you're an IT professional or a private user, there are times when the hard drive has to be totally wiped. These reasons range from reallocating a computer to another user, selling it or donating it, installing a larger internal hard drive or even just to eradicate some flaky behavior. Unless the computer is ancient, reformatting a Dell laptop is a moderately easy process.
1. reformat-dell-laptop-1.1-800x800.jpg Damaged hard drive is a reason to reformat
Back up any data on the PC that you plan on saving. This can be accomplished by using burnable CDs or DVDs, attaching an external hard drive, using an online backup process or hooking up to the corporate backup server.
  • 2 reformat-dell-laptop-1.2-800x800.jpg Older flavors of Windows include a bootable floppy Set the boot order on the laptop. This tells the computer the order that it looks for a bootable disc. The default is the C: drive, but this can be changed by holding down the Delete key while booting the computer. If you're using a floppy, which is common with early versions of Windows, select the A: drive. If you're using the CD or DVD, then select that drive (usually the D: drive) by using the up and down arrow keys. Save your preference and exit.
  • 3 reformat-dell-laptop-1.3-800x800.jpg A software restore CD Insert the media (floppy or CD/DVD) into the computer, and then reboot. Select reformat and install, which will erase all the data on the drive and install a fresh copy of Windows.
  • 4 reformat-dell-laptop-1.4-800x800.jpg 2.5-inch internal hard drive Keep an eye on the process, as earlier versions of Windows often require manual intervention such as selecting options, or pressing the Enter key at certain times. More recent versions of Windows are typically autorun.
  • 5 reformat-dell-laptop-1.5-800x800.jpg Disk image utility Follow the prompts during the installation and after rebooting it. Use the restore CD to install any additional drivers and utilities. Run the Windows updates, and if you're planning on keeping the computer (or assigning it to another user), then install any necessary applications and data files, and configure the preferences, email and printers.
  • I hope you find it very helpful. Thank you for using fixya.
    Aug 15, 2011 | Dell Inspiron 1525 Laptop
    DVD/CD don't work any more, not recognized by the computer. Driver is missing? Windows Vista
    Try to go this website gur.in, click registry tweaks and on the Tech domain registry look for Restore missing CD drive. Just run it and allow. After that restart the laptop. Check if CD/DVD drive is back and test a disc.
    Hope it works!
    Mar 12, 2011 | Computers & Internet
    I have an acer 7730 laptop. I need to reformat the hard drive. It has vista on it. But it is missing files and has virus on the computer. How do i reformat this unit with out a cd? Can you help.
    sorrry with out the cd u can not able to formate if u wana try
    its ur bust of luck it will be done via usb boot
    it need to create a bootable pendrive that to u have to create it
    for more breif how to make a bootable drive with ur minimum 2gb pendrive just reply e i can guide u
    Mar 02, 2011 | Computers & Internet
    Eee pc 900SD. It wont boot up. say's file is missing or corrupt. \WINDOWS\SYSTEM32\CONFIG\SYSTEM. There is no cd\dvd rom so can i use flash drive or memory stick to replace that file? Cheers Don.W.
    systems32 is part of operating system. and your computer is corrupted. Only solution is to reformat your computer by installing fresh operating system. Don't worry, you can borrow from any of your friend his EXTERNAL CDROM or DVD DRIVE to reformat your computer.
    Dec 17, 2010 | ASUS Eee PC 900 Notebook
    My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
    you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
    control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
    hope this helps
    Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
    My cd/dvd driver is not working on my hp notebook
    Go to HP's support website, find your laptop, and get the missing driver, or find out what brand your cd/dvd drive is and go to the manufacturers website to get the driver. I hope this helps!
    Jul 24, 2009 | HP Pavilion dv9000z Notebook
    Having major issues with reformatting Acer Aspire One
    Sure, calm down. You need to get a bootable cd like UBCD. This cd not only boots, but installs a cd driver, allowing full access of CD Drive in a DOS Environment. Check out the UBCD website, download it, and turn the computer on, with the cd in the drive, your computer will boot, so boot the cd, when the options load, hit the key "r", and windows will repair.
    Good Luck
    Jun 18, 2009 | Acer Aspire 4315 Notebook
    Unable to find CD/DVD Drive on Acer Aspire 5610Z
    1. Disconnect your CD/DVD
    2. Uninstall magic iso
    3. Use a good anti-virus and scan all your hard drives.
    Reconnect your CD/DVD. Verify if it works.
    4.If not, right-clic "My computer", manage, select disk manager, assign a different drive letter to all drives but C:. Reboot. Verify.
    5. Lastly, make a backup, reformat all your drives, reinstall Windows.
    Mar 27, 2009 | Acer Aspire 5610-4648 Notebook
    Reformatting compaq presario
    I wanna ask one thing, does your compter show CD/DVD drive in My Computer menu? If yes, then its hardware of DVD/CD drive problem, not a virus. Clean the lens of drive with fine cotton swab, hope it works/ reads.
    Jun 01, 2008 | Compaq Presario 700 470024-192 Notebook
    Acer Aspire 4520-5582 Notebook Logo
    185 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
