Question about Frigidaire GLTF2940ES Front Load Washer
Ddo error - I have the magnet, where does it go?
Where does the magnet for the detergent door go?
  • 3lefthands Dec 22, 2007
    have magnet< still cannot find where it goes? lots of laundry piling up!
  • Anonymous Mar 16, 2014
    locate magnet
If u open the drawer dispenser magnet goes on the right hand botton side good luck
Posted on Dec 22, 2007
3 Suggested Answers
SOURCE: Fridgidare Model #LTF2940ESO won't start Error Message DDO
The code means the detergent door is open. There is a magnet placed inside the detergent door cover housing that has probably fallen out. This magnet completes a circuit when the door is closed. It usually happens when cleaning the compartment and can usually be found stuck somewhere on the washer metal body itself or somewhere on the path you took while taking it to wash it out. Take the detergent tray out and dissamble it by pushing open the plastic tabs that hold it together. Look for the small 1"long magnet. If there isn't one. take your tray assembly to a repair dealer and have them put a new one back in. It is just a few dollars and your problem will be solved.
Posted on May 12, 2009
rickead1
  • 1998 Answers
SOURCE: can't find where magnet goes on detergent door
If you are getting a DDO error code this is due to the small magnet on the right hand side of the detergent door. The easiest way to replace the magnet is to pull the detergent door all the way out. After you have removed the detergent door flip the door over and look at the bottom side of the door you will see a small slot magnet fits vertically in a slot on the left side if you are looking at the door right side of the door if you were looking at the dispenser upside down in the white plastic. If you have any further questions message me back. I await your reply.
Thank you
Rick
Posted on Oct 25, 2011
Can't find where magnet goes on detergent door ddo error. found rectangular magnet
The answer to your problem requires an advanced level of detail. I would suggest you contact an Expert through the PRO and Marketplaces.
I know this is not the answer you expected, but is the best recommendation that I can ask. Thank you for using FixYa.
Oct 24, 2011 | Frigidaire GLTF2940ES Front Load Washer
Washer is reading ddo. what does that mean?
Hi
Error DDO means dispenser drawer open. This error appears when the washer senses that the dispenser door is not closed. If the dispenser door seems to be closed then it seems to be an issue with the magnet. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch & signals the washer that the drawer is closed. This magnet might have moved from its place and that's why you are getting error DDO. Pull the drawer out and check the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Hope this helps... Please post back if you need more information.
Daniel
Jan 13, 2011 | Frigidaire Washing Machines
Display shows ddo error and doesn't start
The meaning for ddo error means"Dispenser Drawer Open" .To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
Jul 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front load washer with ''ddo'' code
The DDO trouble code means that the detergent(D) dispenser(D) door is not closed properly((O)open).
The door uses a reed switch and a magnet to send the door closed signal to the control card.If the
magnet becomes dislodged you will get this code.You will need to have the magnet replaced in
its proper position to clear this code.
Apr 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Ddo problem
Hi
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995430112.pdf
You can glue the magnet back and the error will go way.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 17, 2009 | Frigidaire GLTF2940ES Front Load Washer
Ddo error code on frigidaire front washer
Hi
Frigidaire exploded parts catalog
Thanks
Rylee
Aug 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
We are getting an error code ddo on our wahser?
The DDO error is telling you that the detergent door is open. This error occurs when the detergent door has not latched properly when the unit is started.
There is a sensor that is dependant on a magnet, that is attached to the door, to trip it and send the proper door closed signal to the control oard. If this magnet comes off, or loose the signal will not be sent to the control board, and the error code will be displayed.
Now for the bad news. The magnet is in such a position that a considerable amount of labor is required to replace it.
Unless you are mechanicly inclined and handy with a box of tools I do not recommend that you attempt this repair. It is very involved and is not a DIY repair. It is best to let a tech handle this repair. An approximate price range for this repair is $175.00 to $275.00, or more depending on where you live.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Jul 27, 2009 | Kenmore 43142 Front Load Washer
Mar 20, 2009 | Frigidaire Washing Machines
Washer
DDO is dispencer door open
the magnet needs to be put back into the dispencer door the machine thinks the door is open...
let me know
Aug 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire + ddo error code
Excellent solution. I had a similar problem. The trick is to figure out where to put the magnet. I had a hard time with that.
For those like me who might have difficulty finding the spot for the magnet, it goes on the right hand side of the detergent door. The easiest way to do it is to pull the detergent door all the way out of the machine and look at it such that the back of the door is facing you. The magnet fits vertically in a slot on the left side as you are looking at the door (right side of the doorwhen inserted in the machine) in the white plastic. It sits vertically and is held by a small latch. This is not obvious at all...
Jun 25, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
213 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
