I just replace a Honeywell T87F28733844 Thermostat with a Honeywell RTH221 Thermostat since then my the furnance will not produce any heat. I replaced the thermocouple, but still no go. The pliot light is lit, but still no go. The wires that went to the T87F are yellow, green red and blue. The RTH calls for a yellow, green, red, and white, with a jumper jack in the Rh Rc. The blower for the fan works, and the ac works, but not the heater
  • charlwoo9 Oct 06, 2009
    Hey, thanks I went and brougth another theomstat and I do believe that I just had my wiring wrong. I wired it according to the colors, but I think that I took one color to be another, and I was not sure where the blue wire should have been connected. I'm in the process of rewiring it now, but still you provide some good information.
    President:
  • 1,865 Answers
The heat circuit uses 2 wires to the thermostat one is the power from the transformer, and the other goes to the gas manifold.
The Rh and Rc is probably the power for heat and cool, and this is where the red would attach IF the red wire is the power wire from the transformer.
open the unit and look to see what color goes to the gas manifold. If you have it wired correctly, the problem could be either a blown fuse (if equipped with a fuse) or a bad gas manifold.
You can check the manifold by either using a ohm meter and check the manifold coil or by applying power directly to the manifold from the transformer.
Disconnect the wires from the manifold, and use a meter to see if the coil is good or use 2 jumpers and connect them to the manifold and see if it opens
Posted on Oct 04, 2009
Need to know if it will work
Think you need a different thermostat...you will need one for line voltage, not low voltage.
Dec 08, 2013 | Honeywell Programmable Thermostat Heater
Yes,a little more inf.that ight help solve my problem a little quicker.let me start from the begining.my wife kept switching from heat to air until my themostat finally stop working.it use to be hooke
Only the original new manual will give you the wiring. The bad news in manufacturers do not always use the t=same colors to d the same things. God Bless
John. Same happened to me and I guessed till it started functioning properly. Sorry
Apr 16, 2017 | Honeywell Programmable Thermostat Heater
Honeywell heat/cool thermostat keeps turning furnance on
This is not the thermostat, it is most likely the controller in the furnace.
Aug 10, 2012 | Honeywell Heat/Cool Thermostat
Honeywell RTH221
Try bypassing the control board by jumping the L1 wire with the high speed motor wire, if the motor runs then the board is faulty and must be replaced. If the motor does not run either the capacior is bad or the motor itself
Jul 08, 2012 | Honeywell Programmable Thermostat Heater
Old thermostat has 2 wires. how to I wire my honeywell rth111/rth221? thanks, Rich
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2060EFS.pdf this should be the instructions for that t stat. best to just look at which color came off what letter and replace back on that letter. you dont know if the last guy wired it right
Feb 13, 2011 | Honeywell Programmable Thermostat Heater
I have a honeywell RTH111/RTH221 I put de red wire ont Rh, but where do I put the black wire? Thanks!
If you just have two wires and it controls heat only put black wire on W, or W1 if there is no plain W
Jan 22, 2011 | Honeywell Programmable Thermostat Heater
Replaced mercury thermostat w/Honeywell CT87K - doesn't work!
You need a specific thermostat for a Wall Furnace it is a Millivolt Thermostat and not a 24v standard thermostat....usually it will work anyway however if the powerpile (generator produces millivolts from the pilot light) is weak it may not be producing enough...or the Pilot light may be dirty and lazy...won't produce enough millivolts ...or you can have bad or dirty contacts or connections....or a combination of any of the above.....a 24v Thermostat and particularly a non-mercury thermostat has too much resistance in it for a millivolt system....as your Wall Furnace (other than the fan) runs on less than 1 volt
Oct 31, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell T882 Chronotherm Clock Thermostat needs replacement
The two wires from the transformer are to run the clock in the old thermostat. If you connect the two other wires to any heating thermostat, it will work. Don't forget to disconnect the transformer wires. Hope this helps
Nov 10, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
