Question about Zodiac Pacer Pool Cleaner
My Barracuda was working the other day before the
Our Barracuda was working the other day before we had new items installed. We had a new pump and chlorinator installed. The barracuda sucks but it doesn't vibrate. We also lost flow to our pump at one stage too while the barracuda was in the pool. The pump appears to struggle when it it is attached
  • 990 Answers
If your moving water it sounds like you have a suction valve that needs to be reset to the cleaner. If your main drain is plugged off as it should be with a suction cleaner, the pump will strain. Or it may be a plugged line. Check this by putting a small kitchen sponge it the skimmer and see if it gets pulled through to the pump basket. If it does not get there you have a plug.
Posted on Oct 04, 2009
Bios cannot read hard drive
Hi Robert,
IT could be that the Barracuda drive is formatted for boot up. I would boot up with the drive that boots, and make the Barracuda a spare drive, so you can go in and first see if has any issues as a drive,(meaning sector 0 errors, and if you can access it, then you can format it as a boot up drive, or get what data on that drive off for your friend.
Good Luck Mark
Sep 01, 2014 | Seagate 1TB Barracuda Internal Hard Drive...
How can i connect a seagate barracuda hard drive to a sony vaio desktop pcv-rz22g? i'm installing an a additional hard drive but can't seem to find a sata connector on the motherboard, so there's no way...
You can't find a SATA connector because there isn't one. That computer was built before SATA drives were widely available. You will need a Serial ATA controller PCI card to connect your SATA drive to your computer, such as here:
http://www.compusa.com/applications/category/category_slc.asp?CatId=1455&name=Serial-ATA-Controllers&
Make sure it is a PCI card and NOT a PCI-Express (or PCI-e) card, as your computer doesn't have any PCI-Express slots either. Here's an example of what you need:
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=3501402&CatId=1455
Also, the Barracuda is probably a 3.0 Gbps drive, but will only run at the slower 1.5 Gbps speeds from the PCI interface cards. Again, it's an age thing. That computer was a top dog in it's day.
Dec 20, 2010 | Sony VAIO Digital Studio PCV-RZ22G PC...
Loss of hard drivers
What is happening that leads you to the conclusion that you need the drivers for your hard drive? With Windows 7 you shouldn't need any drivers for your hard drive. If you replaced your motherboard it may require you to reinstall your operating system, being that the OS on the hard drive configured itself to the faulty motherboard when you first installed it.
Mar 20, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
Our Zodiac Barracuda pool cleaner isn't working
you may have a bad diaphragm inside the unit. Unthread the nut between the "wagon wheel" and the lower unit and remove it, push down on the white tube until it comes out of the bottom of the barracuda. Inspect the rubber diaphragm for debris and deformations. If the diaphragm has a large gap inside, it won't work properly. It needs to have only a small uniform gap, they can sometimes even look completely closed when they are new. Replacing the diaphragm will most likely make the unit run like new again.
Nov 14, 2009 | Zodiac Pacer Pool Cleaner
My boyfriend purchased a barracuda G3 2 days ago. After installing it worked really well for approx. 2hrs then the pressure increased to 20 eventhoug he had backwashed the pool and it was very clean. What...
Try backwashing again, this cleaner will pick up enough dirt in a couple of hours to clog the filter. Untill the pool is clean you need to backwash and check the baskets, (skimmer and pump pot) Probally two to three times in the first day, then once after a couple of days. After that you can get back to a regular routine.
Sep 29, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Will cloned Hard drive work with new MoBo and CPU
No, it's not true, but you will need to buy Partition Magic to clone the smaller drive onto the larger one.
The new MoBo and CPU might give you more trouble though. All of the windows drivers for the old MoBo will be confused when they see all new hardware. In the olden (WinNT) days, this rarely worked. Now in the WinXP SP3/Vista days, you'll probably be just fine.
Sep 01, 2009 | Seagate Barracuda 7200.9 500 GB ATA-100...
Install a seagate 7200.7 in a cool max enclosure
They sure are !
You need an IDE or EIDE enclosure.
If you bought the enclosure very recently you may want to try taking it back and swapping it for another one
If its a big box store you might want to try the "it just doesn't work and I am clueless" routine
Seen that work quite a bit much to my dismay. Then the people usually get money back and go to another store to get the correct item.
NOTE I dont condone that method !
Aug 20, 2009 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Accelerator pump problem
I would change gas brands, it may be an additive they use, have seen this before on my own car, a 1973 NOVA, I went to a carb shop they sold me a Viton rubber pump, changed gas brands installed the pump and problem went away.
Sep 10, 2008 | 1983 Plymouth Gran Fury
New internal hard drive not showing up
Did it showing on MY COMPUTER AND MENAGMENT CONSOLE???
Nov 15, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Zodiac Pacer Pool Cleaner Logo
334 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
