Question about Smeg SUK61MFX Gas Kitchen Range
OVEN USED WITH BROKEN DOOR SEAL, OVEN HEAT HAS GONE INTO OVEN BODY AND MELTED SOME WIRING, STOPPED WORKING NOW. Have bought and fitted a new door seal, what do I do next, can I buy individual wiring parts to replace chard ones? Thankyou
    Sergeant:
    Champion:
  • 205 Answers
Hello sir/mam
good you have changed the door seal but you cant do the wiring because if the wires are fully burnt it is difficult to notyfy which wire is connected to which part of the oven so please call the engineer he will do it.
Posted on Oct 04, 2009
While using my dacor microwave, I started to notice a plastic like smell, and then noticed the glass door had fogged like a seal had broken. What's going on?
Some ovens use a plastic material, which is impregnated with a ferrite material, to choke microwave leakage at the edge of the door. If this is melted, the oven should not be used, and it would have to be replaced. After replacement, a leakage test would have to be done.
Nov 15, 2016 | Dacor Microwave Ovens
Fitting heat element sa410x
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 11, 2012 | Smeg Ovens
We have a 5 ring Lofra oven (all gas) and live in spain and the seal on the oven door has perished - we need to replace it but it seems Lofra UK has gone bust and from reading reports, Italy is not helpful...
There are many types of seals that can be used which are universal and not specific. You must check with the Kitchen appliances spare parts dealer for assistance. Take along the sample of the gasket to get a look alike type.
Also there are many available in shops that sell penumatic tubings specially silicon gaskets. Only the groove need to match with the heat resistance characteristics.
Sep 15, 2010 | Ovens
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
2004 jeep gran cherokee door locks and windows do not work interior lite stays on
SOUNDS LIKE YOU HAVE BROKEN WIRES BETWEEN THE LEFT FRONT DOOR AND THE A PILLAR..OPEN DRIVER'S DOOR,YOU WILL SEE A RUBBER BOOT BETWEEN DOOR AND BODY..PEEL IT BACK FROM BODY OR DOOR AND LOOK FOR BROKEN/PARTIALLY BROKEN WIRING..THIS HAPPENS BECAUSE THE DRIVER'S DOOR IS USUALLY THE ONE USED THE MOST..YOU ARE BETTER OFF REMOVING DOOR PANEL AS WELL TO ACCESS WIRING END CONNECTOR SO YOU CAN SPLICE IN A NEW SECTION OF WIRE..USE THE SAME SIZE WIRE AND SOLDER/HEAT SHRINK CONNECTIONS..ALSO CONNECTOR HOUSING IN BODY WILL COME OUT OF BODY AND YOU CAN UNPLUG IT..TRY NOT TO HAVE ANY OF YOUR SPLICES IN BETWEEN DOOR AND BODY..WILL BREAK AGAIN..I HOPE THIS HELPS..I HAVE SEEN THIS PROBLEM BEFORE A FEW TIMES
Sep 23, 2009 | 2004 Jeep Grand Cherokee
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Smeg SUK61MFX Gas Kitchen Range Logo
214 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
