Question about Epson Stylus Photo R1800 InkJet Printer
Epson Stylus CX8400 Paper Jam Error
I just got and installed the printer the very first print it jams. I pull out the paper and notice the bottom right corner is missing in the printer. I end up printing 2 pages, than get a printer jam error. I cannot see any paper in the printer, but I still get a paper jam error.
  • 3 more comments
  • schtumpy Jan 06, 2008
    My paper went in on an angle and never came out . I can't see the paper but its in there somewhere
  • ginger 25 Dec 24, 2008
    Keep trying to print on my epson cx8400. It will print 4x6 photos with no problem. When I put in a 81/2 x11 paper one side keeps jamming. Was printing fine and this happened. No paper was torn in their. It seems like 1 roller is not working. How do I fix this. I spent enough money on it. And I only had it for 1 yr and used moderatley. This should not be happening.
  • Ginny66 Jan 05, 2009
    After every print job the printer shows a paper jam error. I have to turn it off and then back on before it will print again.
  • Anonymous Mar 12, 2014
    paper jammed, removed, then printer would not print
  • Anonymous Mar 28, 2014
    Printer says there is a paper jam but there is no paper in the tray, what can I do to fix this
    Problem Solver:
  • 4 Answers
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
  • Epson Master
  • 1,879 Answers
That missing piece got stuck inside the printer,
immediately contact the place of purchase for replacement or the manufacturer (they will cover all shipping cost)
Posted on Jan 04, 2008
Paper jam
Your having a hardware issue and you need to have it serviced.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Mar 27, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus Photo 1390 Paper Jam
It PW sensor error. For "Normal Quality" mode, the PW sensor will not work for "reading" paper existence, but for "Fine", photo and best photo it work. PW is paper widht. Small sensor at bottom side of carriage, near the head. Dirty or short circuit may be.... Can you fix it?
Jan 13, 2013 | Epson Stylus 1400 InkJet Photo Printer
Epson stylus Photo TX720WD jam paper solutions
epson tx 720 wd printer error turn power off and then on again for details see your documentation
Feb 06, 2012 | Epson CX8400 All-In-One InkJet Printer
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Message: Error paper jam. There is no paper jam.
Yes there is some micro piece of paper is under a sensor somewhere Get serious and pull it apart, what have you got to loose! Inkypete
Apr 20, 2009 | Epson Stylus Photo RX500 Printer
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson CX2900 problem
HI,
Try to reset it :
SSC Utility has the latest version SSC Utility 4.30... This time it can now reset the Epson Stylus CX2900...
Download the latest version and Install it...
Under Configuration...
Select Installed Printer (EPSON Stylus CX2900 Series)
Under Printer Model
Select EPSON Stylus CX2800...
I hope this will help you. Link
Aug 02, 2008 | Epson Stylus C84 InkJet Printer
Paper jam error
your software doesn't have problems... its your printer itself or the way you put on the paper that's why its always having error....
Feb 14, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
2,428 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
