Belt came off hotpoint washer
Hotpoint belt has come off and we dont know how to put it back on it hasnt broken jsut came off and it wont go back on what do we have to do to get it back on is there a solution plz reply back
    Sergeant:
    Champion:
  • 205 Answers
Hello mam
before trying please check the belt tension. and if you inspect the threads are visible on the belt which will be seated on the pully please change the belt and to put it back
1.plase the belt into the motor pully first. and then using a screwdriver hold the belt into the drum pully slowly rotate the drum as you rotate the drum you should hold the belt along the pully.
Posted on Oct 04, 2009
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came lose.....open up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How to put a belt on
remove lid and bottom cover 2expose moter pully lean washer towards u pass belt down and put over motor pully then start putting on drum pully can b very tight good luck
May 03, 2009 | Washing Machines
Washing machine not spinning
Its a pain on this model but heres how. First remove plate at back of machine. Remove belt and two bolts holding motor (13mm).Unplug motor and remove. brushes are at back end of motor in plastic housings. after refitting motor replacing belt is where the fun begins. Put bottom end on first and feed round pulley. ouch
regards
Dec 04, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine
  • if it is neither draining noe spinning check If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • Aug 22, 2008 | Hotpoint VBXR1090D Top Load Washer
    Need to change tumble belt
    REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
    To do the belt...
    1. UNPLUG the washer.
    2. check you've unplugged.
    3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
    4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
    5. Lean over the drum and see the large drive wheel.
    If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wd64&part=belt.
    6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
    7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
    8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
    9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
    10. replace lid, torx and cover for torx.
    - If the belt is not broken in your case - it could be the brushes on the motor - I can give you info on this if required!
    Please dont forget to rate me as fixya.
    Jun 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
    Hotpoint wd64 washer dryer
    mits86 , you are correct - it could be the belt.
    To do the belt...
    Mar 07, 2008 | Hotpoint Aquarius WD63 Front Load...
    Whirpool washer
    I will need the model number but just by what you have said it sounds like your coupling has broken. are you mech. inclined?? plz post the model so i know what we are working with it will be on a tag under the lid on the back wall of the frame closest to the hinges (centered)
    Feb 16, 2008 | Washing Machines
    Hotpoint washing machine belt come off
    u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
    Dec 29, 2007 | Hotpoint First Edition FEW12 Front Load...
    How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
    The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
    Oct 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
    Washing Machines Logo
    134 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
