Question about Blaupunkt Car Audio & Video
I have just got a peugeot bipper van, it has a blaupunkt 2250 mp3 cd radio with blue tooth. the problem i have is ican get my nokia phone to recognise the signal from the radio but the phone does not conect to it. the phone is a nokia n96 with blue tooth enabled. every time i get in the van and switch on the ignition there is a verbal warning for me to pair device. but i cant! am i missing something here. please help
SOURCE: Conecting Blue tooth phone to acer laptop
Visit this link to download the bluetooth driver http://support.acer-euro.com/drivers/notebook/as_5630.html
Posted on Jan 06, 2008
SOURCE: Have a Blaupunkt AM FM
We eventually tried loading another CD to fill the one vacant spot we knew was in the changer even though we'd tried that before without success. This time it seems that we fluked it just as it was trying to eject CD 1 again and - somehow - the CD we were tryng to insert must have lifted the rim of the one that was stuck and it suddenly ejected. The remaining 4 CD's that were inside the changer but not even recognised, then started re-loading so it appears that they were all jammed up together. Once they'd reloaded we were able to eject them all successfully then reload.
We're not sure but think that it may have happened when the eject button was originally pressed once to eject CD 6 then, in error, held down for a 'eject all' procedure and the changer has become confused with both instructions.
Posted on Jun 02, 2008
Benimur
  • 6966 Answers
SOURCE: I have a peugeot 207cc
I would venture that the main B+ wire of the Blaupunkt CD Changer is not connected to an always on B+12 such as the positive terminal of the battery. This wire is responsible for memory/location/track last play retention. The other B+ of the CD Changer is the remote trigger on which is fed by and from the head unit. This in effect makes the unit operate with two (2) B+,an always on and a triggered on.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 10, 2008
  • 848 Answers
SOURCE: blue tooth
just go to control panel and enable bluetooth in your pc ...if problem continues there may be some virus in your pc blocking the bluetooth connectivity check and remove it
Posted on Jun 14, 2008
JigSaw007
  • 157 Answers
SOURCE: my blaupunkt cd changer on
maybe youvr set it up to loop on one song
Posted on Aug 30, 2008
How do I remove spare wheel from bipper van
Find the release bolt from underneath, measure the bolt position relative to edges or some other defined point that you can follow through the same points/edges to the top (you may have to estimate a little) and work out where to drill or remove the ply to reveal the release.
May 14, 2014 | 2010 Peugeot Bipper Teepe
Van no start breakdown diagnosed ignition module fitted new module had it coded at dealership still no start told it is a wiring issue between ecu and ignition module but cannot find any wiring plans for...
Didn't get the model of your van...many times the "crank position sensor" creates this problem...Also many auto parts stores offer free diagnostics...stay away from the costly dealership...talk with a local repair shop about a free diagnosis:) Hope this helps.
Oct 31, 2013 | 2010 Peugeot Bipper Teepe
Hi Can anyone be kind enough and give me a code for blaupunkt 2040 from my peugeot 206? 14 digit code is BP8146x2387842 and the 10 code is 7648146392. Many thanks
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Peugeot service centre and get them to enter this code for you.
Dec 04, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Audio
Anything is possible with a bit of fore thought ,take old one out then try to fit the new one the wiring plugs should be the same for two of them but the third one will work the changer so leave that disconnected
Nov 29, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
How do you reset the service light on a peugeot bipper 2009 model
you can use a tool to read out the code and then reset the light, I know this tool can do your car, hope help.
Jul 05, 2011 | Peugeot 405 Cars & Trucks
How do your lock in your radio code on a t reg peugeot partner van after entering in the code.
It all depends on the actual MAKE and MODEL of your radio
Most Peugeot radios are made by Blaupunkt , Philips or Clarion so check this site for your actual instructions ( Click on the radio MAKE and enter Peugeot in the Search box)
http://www.radio-code.co.uk/code-entry-help.php
Jul 16, 2010 | Car Audio & Video
Bought a peugeot 206 w reg april 2000, registered with locked radio and don't have code,how do I decode?
If it is a stock radio, you will have to phone your Peugeot dealer and give them your VIN or chassis number. They will then track your number through your Chassis number
Jun 08, 2010 | Blaupunkt RPD-545 CD Player
Blaupunkt GMBA radio to boxer van discnected to
The instructions should be one of these
http://www.radio-code.co.uk/post_in_radio_code_model_selection.php?m=Blaupunkt&search=peugeot&Submit=Search
Oct 16, 2009 | Blaupunkt Car Audio & Video
Peugeot 307 BP905038637756 7607769050, code please?
PEUGEOT Blaupunkt
There may be 2 different codes depending on how old the car /radio  is.
Try 3963
and if your radio will not accept any digits higher than 6 ( ie 6666 is the highest  )
then try 2211
Sep 04, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Car radio decode
hi i can if you can supply the serial number.
Mark
Blue ICE
Feb 27, 2008 | Car Audio & Video
Car Audio & Video Logo
214 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
