Question about KitchenAid KGRT607 Gas Kitchen Range
KitchenAid KGRT607HWH6 temperture, light, error code
I have a kitchenaid superba free standing range kgrt607hwh6.
The oven does not cook properly – the temperature seems wrong. I have already followed the steps to adjust the temperature calibration based on the owners manual
Sometimes when I open the oven door the appliance light goes on – sometimes not.
The convection oven fan turns off/on intermittently while cooking - I think this is supposed to stay on all the time.
Occasionally I get the error code F7 E1, when I hit cancel it disappears.
Is this something I can repair myself?? If so what is the part name/number I should be looking for??
Thanks
  • Anonymous Dec 25, 2007
    F1:E2 error code is what?
  • 15,935 Answers
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
I have a Kitchenaide KGRT607HWH6 the oven gets up to temperature and then displays the F7:E0 code and shuts down What is this error code?
The error code "F7:E0" means "Invalid latch switch reading".
The first thing I would do is check the interlock switch on the door latch and the door latch itself (the door latch assembly is located on the back of the range). The interlock switch must be closed when the door is locked.
If there is nothing wrong, then check the wires from the switch to the control board.
If wires are fine then replace the control board.
Here is the interlock switch
Here is the oven lock assembly
Here is the control board
Nov 29, 2012 | KitchenAid KGRT607 Gas Kitchen Range
Kitchenaid superba f2e1. I have no idea what happened. I was cooking and then this code came up nothing works now. any suggestions?
Hi
F2-E1 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid Superba Gas Range error code F3 E0 when trying to strat the range
The F3 E0 means
Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse Good luck
Nov 27, 2010 | KitchenAid Kitchen Ranges
Hello... range reaches desired temp, food in oven, Beeps F-1, shuts down oven, food not cooked... huge problem kitchen aid supra electric range
You may need to see the secondary error code (F1-E?). The chart below is for a KitchenAid Range. Most likely is a control board issue. We rebuild control boards if you want to save some money compared to new.
Nov 02, 2010 | KitchenAid Kitchen Ranges
Kitchen aid superba oven is getting a error code of: F3-E0 the temperature won't go over 250
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Sep 29, 2010 | KitchenAid KGRC608LSS Gas Kitchen Range
Superba KGT607HBS oven stopped working
The flame went out.  Move the oven control back to where it sounds like it is lighting.  After it clicks a few times and sounds like you have a flame set your temperature again.
Nov 27, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Jan 15, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGRT607 Gas Kitchen Range Logo
614 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
