Don't reset password BIOS HP DC7100
Don't reset password BIOS HP Compaq DC7100
  • 154 Answers
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Posted on Oct 04, 2009
  • 4,281 Answers
For that open cpu cabinet then pull cmos cell for 10 minutes.
Also you can clear password with jumper settings find jumper on motherbord named "CLEAR CMOS"
it has 3 pin set it to 2-3 position then power up then again set it to 1-2 position then it not ask for password.
Let me know if you need more assistance.,
Thanks.
Thanks.
Posted on Nov 08, 2009
I forgot my power on password. How can I resolve this problem.
open the computer and look for the bios battery, (a small round silver disc in a holder) remove it for a minute or so and put it back in. If you restart the computer, the bios is reset and you won't have to enter the password.
Jun 18, 2011 | HP Compaq dc7100 PC Desktop
I forgot my BIOS password and i can't access it becos i don't know the password.
HP Spare Key can be used to reset BIOS password. It is provided by HP Corporation. So when you forgot BIOS password on HP computer, just download it and get perfect BIOS password reset.
How to reset HP bios password with Spare Key or other ways?
Please refer to reset HP Elitebook password. In this passage, you also can learn how to reset Windows administrator password easily.
http://www.isunshare.com/windows-7-password/reset-hp-elitebook-password.html
Jun 12, 2011 | HP Compaq 6730s Notebook
Picked up a HP dc7100 but will not boot from sata
You should have an option on the dc7100 in bios to enable sata in the devices section. Mine always worked fine with sata. If nothing else works remove the security chip, reset the cmos and reboot with the Hard Drive connected and it should connect. If that doesn't work Try flashing the bios just in case it got corrupted.
Mar 12, 2010 | HP (REFURB) HP DC7100 XPP P4 3.2GHZ 80GB...
When trying to power on the red led light at the front of the unit is constantly flashing and will not power on, any ideas?
According to the Compaq Service Reference Manual (http://www.manualshark.org/m/hewlett-packard-hp-compaq-dc7100-convertible-minitower-pc-hp-compaq-dx6100-and-dc7100-series-personal-computer-service-reference-card-28379/) There are several codes listed but not for a steady red LED. Try first unplugging the unit, press and hold the power button for 5 seconds to clear any residual charge in the machine. Then plug it back in, turn the power on and note the error codes. Compare the codes with those of the document link I have posted. Both the keyboard and chassis LED's will display error conditions accompanied by a series of beeps from the units speaker. It sounds as though you have a hardware failure, but until you can verify the error codes with the HP/Compaq service manual, I can't say for sure.
Nov 27, 2009 | HP Compaq dc7100 Ultra-slim PC Desktop
How to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
I wnat to bios update for hp compaq 915
go online to the bios manufactures website..and update it..
Apr 22, 2009 | HP Compaq dc7100 PC Desktop
Power on password
Reset the bios it will passwords
Mar 01, 2009 | HP Compaq dc7100 PC Desktop
Dc7100 sff power supply
Part number :
349987-001 Switching power supply (340W) - 100-240VAC input, 45-66Hz
Aug 24, 2008 | Compaq dc7100 Small Form Factor (PJ361UA)...
How to resets bios for compaq 2514 at
Why? What happend? Is it asking for a BIOS password?
If it is asking you have to short two jumpers on the systemboard to have it reset.
If not, just go in to BIOS by pressing F2 then restore or optimize default settings on BIOS.
Hope this helps...
Jul 24, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
3,358 people viewed this question
David Payne
David Payne
