47 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 20, 2009
I have a sony model KV36H5500 when you turn it on there is no picture no
sound. Red light blinks 6 times and continues.
Comment by den0067, posted on Jan 10, 2009
We have a Sony KDFE50A10 3LCD wega engine, A repair man said its the lamp, is thre a cheap way to fix this
Comment by JS1scuba, posted on Jan 07, 2009
Sony KV-35S42 screen went black -- when i press power button i get blinking red standby light. Can this be repaired ?
Comment by mdeluca389, posted on Jan 03, 2009
my sony 50" inch tv model number kf-50we610 no picture no sound and the red light flashes 4 times.
Comment by fixall123, posted on Dec 26, 2008
sony 53 inch tv red light flashing no sound or picture
Comment by Guest, posted on Dec 24, 2008
My tv is stuck in timer standby.Blinking red light
Comment by Guest, posted on Dec 19, 2008
the t.v. will not turn on-no sound no picture-the stand-by light just flashes!!!!!
Comment by groveboys151, posted on Dec 04, 2008
When I turn on my sony 50 inch model # kdf- 50we655 it doesn't do anything but blink the red light. what does that mean. thank you
Comment by Guest, posted on Nov 29, 2008
Sony Picture in picture model No. KV534MH1 made in japan.
Problem in power supply board.
Comment by Guest, posted on Nov 26, 2008
Hi my Sony TV wont turn on and it has a 9 light flash standby
Comment by sandisim, posted on Nov 17, 2008
my sony big screen was built in 2000--i have sound but no picture---the timer/standby light flashes continuosly
sandisim@yahoo.com
Comment by ashurhonda5, posted on Nov 08, 2008
My sleep timer red light is on my tv and it sounds like it is going to cut on but does not. How do I fix this?
Comment by RVFD903, posted on Oct 31, 2008
Hello this is my first time on here i have a sony 36FS120 on picture or sound standby timer flashes 9 times pause 9 times any ideas on this one
Thank You
Comment by tdtran, posted on Oct 29, 2008
I have model KV-36HS500, when turn on, no picture and standby LCD blink 7 times. Some one suggest that the IC8002 and/or IC6501 on D-Board (pn: MCZ3001D) went bad. Any advice? Thanks.
Comment by Guest, posted on Oct 19, 2008
my sony wega t.v. will make sound when u turn it on,but no picture will appear!!!!! then a stupid little red light flashes like 4-6 times???WHY??
Comment by timski101, posted on Oct 17, 2008
Sony Trinitron. Push button and sound comes on and standby flashes. Last time was 14 flashes before picture came on. Then picture continues to flash in and out, lessening as tv "warms up". Intermittently flashes throughout the day/night seemingly turning off and on for a split second. It seems to be getting worse...
Comment by Guest, posted on Sep 21, 2008
my sony 51 in ,, standby flashes 6 times....no sound or picture. just makes power clicking sound when u turn it on, then standby flashes the six times
Comment by teinemane, posted on Sep 19, 2008
My sony tv is not working, there is no pictures and sound, just turn on and the red light goes back out. It is to big to take out to a repair place. I need assistance in solving my tv problems. My name is Ola Morisa and here is my phone number-907-242-7877.
Comment by LeeHuth, posted on Sep 16, 2008
Our tv went off suddenly and there is a red blinking light- when trying to turn it back you can hear the power click on/off.
Comment by Guest, posted on Sep 12, 2008
same problem flashes 6 times
Comment by eagle1031, posted on Sep 05, 2008
Starts out with sound and then goes to standby and blinks 5 times or 10 times. Have followed the manual and hit the reset and then the off button and then release the reset. It worked for a while but had to be done several times them finally would not reset.
Comment by vinbarboza, posted on Aug 28, 2008
my tv has the red light flashing some time it goes on some time it wont
Comment by FredSONofMAC, posted on Aug 26, 2008
Have the exact same problem. At first, after trying a few times the TV would go on but now I just get the flashing standby light. Is there any help for dedicated SONY customers? or is it time to find another brand?
Comment by gem404, posted on Aug 20, 2008
If the tv goes blanc and the led flashes twice continually, is there a way i can repair or do i need an expert?
Comment by Guest, posted on Aug 09, 2008
Screen goes dark at intervals (usually on abrupt scene changes in the program material, though not always), red LED on front panel flashes for 2-3 seconds times, then picture comes back.
If there are many rapid scene changes, say in a sports event cutting from camera to camera, the screen spends most of the time dark since each new scene change makes the screen go dark again.
Comment by Guest, posted on Jul 31, 2008
No picture - flashes twice in intervals
Comment by jcortell, posted on Jul 30, 2008
The Same problem our Sony Kv-34XBR800. No picture no sound, it will blink six times pause and continue to blink six times again Pull the plug let it set overnight and it will start the next day. Called Q-Service and they want to replace the entire power board? It will cost $500 which $259.00 is labor! Why should I replace the entire power board,Q-Service won't do less. Thanks Sony for making something that only lasts five years!!!
Comment by Guest, posted on Jul 28, 2008
SAME PRBLEM
Comment by allertude, posted on Jul 28, 2008
no picture,standby flashes
Comment by mackthe knif, posted on Jul 20, 2008
TV won't come when hot , red light flashes 6 times. let it sit all night it will come on the next morning, if you cut it off during the day, it won't come back on. model # kv-40xbr800
Comment by Guest, posted on Jun 29, 2008
My sony tv has not been working for 3 days now. the on/off light is flashing 11 times!!! any idears?
Comment by Guest, posted on Jun 27, 2008
Sony model KP53N77 - picture went black while watching. Did the hard reboot and plugged the tv into the wall instead of a surge protector. Nothing works. Power button is blinking in a series of 4 times. It seems this is a common problem with Sonys??? Can you offer advice. Is this worth fixing? Thanks!
Comment by zmerz, posted on Jun 25, 2008
My Sony Trinitron's picture started having problems last night. After researching the internet, it would be helpful if I had a blinking light. For those of you who do have a blinking light, this site might help
http://en.allexperts.com/q/TV-VCR-Stereo-1749/SONY-TV-REPAIR.htm. When I have a picture it's squished and has strong horizontal lines then goes to black; I do have sound. The standby light does not come on. Any ideas?
Comment by Wi-lob, posted on Jun 21, 2008
when I try to turn the tv on it will not power up and the standby light will start to blink. six blink pause then six blink
Comment by annette_t_n, posted on Jun 17, 2008
Yep, tis just happened to us two days ago. I haven't found anyone locally who knows what I am talking about & it is really frustrating!
Comment by Guest, posted on Jun 04, 2008
Like the others, our TV turns on and then the picture disappears and the stand by light continuously flashes. We did the power re-set and it booted up faster but still shut down.
We want to know roughly what this is going to cost to repair and if there are any recalls from Sony for this problem to be fixed for free.
Sony KF-60XBR800
Comment by samroze, posted on May 06, 2008
I have a Sony KP-61HS10 61 inch TV. It is 7 years old now. The TV turned off while I was watching. No picture. No sound. But the stereo light was on. Then I unplugged the TV, waited for few minutes and then plugged in. Now the red timer/standby light flashes continuously. NO picture or sound. Please help me.
Comment by Fyrecherdo, posted on Mar 30, 2008
no picture....red led flashes in patterns of 2...sony kv27fs12
Comment by Guest, posted on Mar 29, 2008
my sony wide screen tv when turned on could first hear a sound but quickly goes to the standby mode,standby light start flashing .
No sound and pictures follow after that.
Comment by jeremy69, posted on Dec 29, 2007
tv just all the sudden went off tried to turn back on then it just clicks twice and red light flashes 6 times
Comment by Guest, posted on Dec 27, 2007
standby light is flashing; tv will not turn on. I have unplugged everything and waited 20 seconds. HELP!!!!!!!!!!!!!!!
Comment by Guest, posted on Dec 26, 2007
stand by/timer light is blinking and i have no sound or picture. I have aleady turned on and off the cable box and and have unplugged everything and waited 20 seconds before plugging back in...still nothing
