Question about Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
    Sergeant:
  • 233 Answers
The jumper settings are listed on the top of the Maxtor drive.
Pin settings are counted 1 2 3 and 4 etc.
Pin 1 is nearest the power plug
Jumper settings for the Maxtor 96147H6 (set as primary slave = no jumper)
Hope this helps!
Posted on Oct 05, 2009
    President:
  • 2,666 Answers
For use as slave there is no jumper connected. (Master on/slave off0
Posted on Oct 04, 2009
Maxtor n256 60 gb HDD jumper settings
Take a look at this pdf:
eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
So If this is layout " : : : . : "
then...
slave -----------
master -------- " [:]: : . : "
cable select -- " :[:]: . : "
Jun 04, 2012 | Maxtor Computers & Internet
Maxtor hd jumper settings n256 91366u4 primary
MAXTOR: no jumpers --> Master
one jumper --> Slave
two jumpers --> Cable Select
Dec 20, 2010 | Maxtor Hard Drive
Slave jumper settings for a Maxtor N256 Hard Drive
I have never personally seen one but most drives are the same for the type of jumpers installed. See if this helps you:
http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
Apr 28, 2010 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Can not find Jumper diagram on N256 Maxtor model 33073H3
Hello there soggytundra, here's your GEEK-steer ...
Despite your question being posted here 5 days ago, I'll presume you still (and if not, then someone else will) need the answer ...
Virtually all Maxtor drives adhere to the following general rules concerning jumper settings (at least up until now):
= MASTER (M): Insert jumper over the FIRST COMPLETE pair of VERTICAL pins.
Examples:
Xoo o oXooo Xooo
Xoooo Xooo Xooo
= CABE SELECT (CS): Insert jumper over the SECOND COMPLETE pair of VERTICAL pins.
Examples:
oXo o oXooo oXoo
oXooo Xooo oXoo
= SLAVE (S): Do NOT insert ANY jumpers (or at least NONE VERTICALLY, but you may HORIZONTALLY across the TOP row as simply a means of storing the jumper).
Examples:
ooo o ooooo oooo oooXX oooXX ooXX
ooooo oooo oooo ooooo oooo oooo
TIP: As a general rule, if you KNOW the role of the jumper capable device you're installing, it is better to NOT use Cable Select (CS). In this case you do, therefore it would be best to specifically designate the (33073H3) drive as (secondary) Slave [and your other (primary) drive as Master].
Good luck and GOD-speed. Please post back if you have any further questions, and/or just to let me (and others in similar need) know how well this steers to solution.
"Today's the best day of my life...and NOW you're part of it!"
Mar 28, 2009 | Maxtor Hard Drive
Jumper setting for maxtor n256 diamondmax vl 40 5400 rpm
There is usually a diagram on the drive showing the jumper configuration.
Mar 16, 2009 | Maxtor Hard Drive
Jumper setting
The first jumper goes up and down on the two pins just beside the IDE cable slot and the other jumper goes across the top two pins next to it
Jan 23, 2009 | Maxtor Hard Drive
Hard drive was freezing up .i have already replaced and reloaded
On the back of the hdd you will see a row of little pins in groups of 2 vertically. It will be marked either right above the pins or on the top of the hdd above the pins, ma, sl, cs. The setting for slave is sl. Put the plastic jumper cap on those 2 pins & it is set for slave. Hope this helps & please remember to rate my answer. Thanks.
Jan 22, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
Maxtor Hard Drive Logo
2,054 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
