Question about Foxconn 6100K8MA-RS Motherboard
What are the connections from the motherboard to the from USB panel as I don't know which pins go into which slots on the motherboard
  • 40 Answers
Use similar cables as connected to the rear usb ports on the adjacent slots on the motherboard.
Posted on Oct 05, 2009
Good day i have mother board asus p5800-mx the usb port cannot work theirs no 5 volts in the port, pleas help me to resolve my problem thanks.
Ashley,
A) There are two USB headers on the motherboard.
They are rectangular in shape, and Blue in color.
One is to the immediate Right of the 3 white PCI slots.
Has 4 pins across the Top row, and 5 pins across the Bottom row.
May have USB56 printed on the motherboard next to it.
The second one is at the Bottom of the motherboard, below the Intel 82801EB southbridge chip; which is to the left of the CMOS battery.
May have USB78 printed next to it
http://www.ebay.com/itm/Asus-P5P800-MX-Socket-775-MotherBoard-NEW-865GV-/221041609289?pt=UK_Computing_LaptopMotherboards_CPUs_CA&hash=item33771b4a49
(Turn motherboard photo 90 degrees to the Left, to be as it sits in your computer case)
EACH USB header supports TWO USB ports.
A Card Reader uses ONE USB header, with it's two cables.
Point?
Front Panel USB ports, are connected to one of those blue USB headers.
This USB header you know to be bad.
If the other USB header is not being used, connect to it.
The front of your computer is the Front Panel.
The USB ports in the Front Panel, should be connected by one common cable, and it ends in a plug on connector.
No? Not feasible?
Then suggest using a USB adapter card, in an open white PCI slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&CatId=511
Product details indicate it has two internal USB headers.
This way you can connect the Front Panel USB ports to it.
http://usa.asus.com/Motherboards/Intel_Socket_775/P5P800MX/#download
Choose ANY O/S, and then download the manual.
Or, here is the direct link to the motherboard manual (PDF file),
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5P800-MX/e2005_P5P800-MX_V2.pdf
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | ASUS P5V800-MX Motherboard
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
Can't find the second set of pins for my USB drive
According to the manual, if you have front panel USB, use the pin set labeled USB3 for these connections. The USB3 connector is located between PCI slot 1 and 2. If you are already using this for the connector labeled 1394....1394 is for FIREWIRE interface and this mainboard does not appear to support it. Be careful of that connection unless you are absolutely sure of yourself.
Dec 25, 2011 | EliteGroup K7VTA3 V6.0 (K7VTA3_V6.0)...
How do i hook up usb button in intel 845 motherboard
Well, that's a start. You know you have an Intel motherboard in your eMachines, that uses an Intel 845 motherboard chipset.
It is an Intel D845GVSR motherboard.
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Left-click on the blue -
Intel Desktop Board D845GVSR Product Guide (PDF)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
(I would advise upgrading to Adobe Reader X { 10 }, however, if you don't have it )
After you click on the above link, it may take up to 30 seconds before the first page comes up. (Took 6 seconds just now. Adobe Reader X, and medium speed DSL connection)
At the top of the PDF file, is the PDF file page number box.
It is to the left of the Down Arrow.
Go to Page 11.
T is the Front Panel USB header.
This is where the USB ports on the front of the computer, (Front Panel) connect to.
Go to Page 31.
E is the Front Panel USB header.
The Front Panel USB header is J9F2.
Observe the numbers next to the pins.
Go to Page 33.
This is the pinout for the Front Panel USB header, using those contact pin numbers.
1, 3, 5, 7, and 9 = one USB port
2, 4, 6, 8, and 10 = one USB port
Notice pins 9 and 10 are not used.
You can connect two USB ports to this header.
The pinout of ANY USB connector, female, or male, is set to a Standard.
This is the standard pinout for USB connectors,
http://pinouts.ru/Slots/USB_pinout.shtml
In case you cannot download the Intel D845GVSR motherboard manual;
Looking at the motherboard in it's normal position, installed into the computer case, the USB header is on the Bottom edge of the motherboard.
It is to the immediate Right, of the bottom white PCI slot (PCI 3)
It is to the Left of the motherboard mounting hole.
It is Below the Intel 82801DB, Southbridge chip.
Two rows of pins.
5 across the Top row, 4 across the Bottom row.
STARTING on the Left side, (Towards the white PCI slot), and going towards the Right, the pins on Top are numbered,
Pins 2, 4, 6, 8, and 10
STARTING on the Left side, (Towards the white PCI slot), and going towards the Right, the pins on Bottom are numbered,
Pins 1, 3, 5, and 7
Pins 1, 3, 5, and 7 = One USB connection
Pins 2, 4, 6, and 8 = One USB connection
Pin 9, and Pin 10 are Not used. (N/C. No Connection)
A) Pin 1 is for Power
B) Pin 3 is for D-
The Data, or Signal wire. It is the Negative connection
C) Pin 5 is for D+
The other Data, or Signal wire. It is the Positive connection
D) Pin 7 is for Ground
Going to the other USB header;
A) Pin 2 is for Power
B) Pin 4 is for D-
C) Pin 6 is for D+
D) Pin 8 is for Ground
Out of curiosity which eMachines is this?
Regards,
joecoolvette
Nov 24, 2011 | E-Machines eMachines Desktop PC
USB 3.0 connectivity to front on GA-Z68AP-D3
As you said the board got the front pin connectivity.
All you have to do is buy in any comp shop a front USB and sound socket for the casing.
It is up to you where to put it on the front panel, drill a hole to fit that outlet and use hot glue to fix it in that position.
Hope that helps!
Nov 21, 2011 | Computers & Internet
Front panel header pin connections how to put the pin in the right place because i put my motherboard in a differen case can u send be a picture so i can know how to do it sony rx660
Don't quote me on this pinout ladydj11, but I believe this is correct;
The Front panel header is located parallel to the Bottom Right edge of the motherboard.
(Motherboard orientation; Processor to the top, Ram Memory slots to the right, PCI slots to the bottom)
There are two rows of 10 pins laid out horizontally. (20 pins total)
I will number the pins for easier orientation.
Starting from the Left side of the motherboard going towards the Right, across the Top;
Pins 1, 3, 5,. 7, 9, 11, 13, 15, 17, and 19.
Starting from the Left side of the motherboard going towards the Right, across the Bottom;
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
A) Pins 1 and 5 are for the Power On LED light.
(Pins 1, 3, and 5 would be used for a dual color Power On LED light. Pins 1 and 3 are for the Positive { + } wire)
B) Pins 7 and 9 are for a Keyboard Lock. Believe the pins are left unconnected for an unlock status.
[ May be the other way around. The two pins may be have to be connected, in order to complete a circuit which allows power to go through the Keylock switch, when it is in the locked position ]
C) Pins 13, 15, 17, and 19 are for an internal speaker. Used for BIOS Beep Codes.
D) Pins 12 and 14 are for the Power On switch
E) Pins 16 and 18 are for a Reset switch, IF used.
Regards,
joecoolvette
Jul 11, 2011 | Sony VAIO Digital Studio PCV-RX660 PC...
What are the basic parts of the intel motherboard?
cpu, video card.hard drive, floppy drive cpu fan, power supply, is the battery good first for cmos, are all the connection right. is the power supply good.is the mem.right in the slots is it ddr or ddr2 do you have the right speed on cpu for board as well as mem , what is the intel board numbers on it d915 or what i need to know which board to find out anymore ok jim
Jul 04, 2011 | Intel Motherboard
Wires for USB go to which MoBo pins?
there is two sets of 4 pin on each with an xtra ground you may not use.
Here is the link for your motherboard manual which shows the connections.
i.e you can connect your two sets of 4 wires to usb 1 or split them i.e 1 set of 4 on usb 1 and 1 set of 4 on usb 2.
http://zhornyak.com/soyo/Soyo_P4X400_Manual.pdf
Oct 06, 2009 | Soyo P4X400 Dragon Lite (P4X400DRAGNLITE)...
Is It required to connect Tower Front Panel I/O to Motherboard
The power button on the front panel would definitely need to be hooked up to the motherboard so you can power up the computer.
If you have any usb slots or a media card reader on the front panel, or both, then you would need to hook those up as well, otherwise the main one you need to connect would be the power button.
May 23, 2009 | ASUS P4V8X-MX Motherboard
Case connector problem
we would need to know the motherboard you have. most i've worked on have a 7 or 8 pin connector near the bottom of the motherboard.... next to the pci slots. if that front devices uses a modular plug it usually has a blank pin slot so you cannot hook it up to say a usb port.
Get out your magnafying glass and a light... the connectors are often labeled right on the board.
Robert
Please rate this solution.. thanks
Sep 08, 2008 | ASUS A8V Motherboard
Foxconn 6100K8MA-RS Motherboard Logo
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
