Question about Remington Electric Chain Saw
Electric pole saw won't start - Remington Electric Chain Saw
SOURCE: Remington Pole Saw
From looking at the breakdown, it looks there are replacement parts for the chainsaw but no replacement parts are listed for the pole . The switch on the pole is what I need. I wonder if the switch on the saw would work on the handle?
Posted on Jul 15, 2008
SOURCE: what type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Posted on May 25, 2009
dontbother10
  • 2220 Answers
SOURCE: where can I purchase parts for the telescoping
IPL
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
Carefully check for a number that matches something on your saw if you find what looks like the correct part.
If you find the correct do a Google search for a possible source and availability . We can do no more.
You know RemingtonPower has ceased production and replacement parts are limited to what is on hand? HTH
Lou
Posted on Oct 20, 2009
dontbother10
  • 2220 Answers
SOURCE: The plastic Pole Lock (Thumb Latch)on my Remington
RemingtonPower is no longer in production, The "Coupling Nut" was replaced by a "Thumb Latch" neither of these nor the entire pole assembly are available.
You might try this (no promises).
http://store.poolcenter.com/shared/StoreFront/product_detail.asp?RowID=167966&CS=poolcenter&All
Someone recommended using a hose clamp in place of the nut.
I think these are band-aids and eventually you will need a part that cannot be found.
We rarely get inquiries for McCulloch or Poulan electric units. Might be worth a look.
If you care to try on your own start here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Sometimes you can find NLA parts (use part number for above) offered here:
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
If you have more questions or need additional help please reply below and I will get back to you. and Good Luck. HTH
Lou
Thank you for using FixYa.
Posted on Apr 18, 2010
dontbother10
  • 2220 Answers
SOURCE: Remington electric Pole Chain saw - what type of oil do I use?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
Some manuals go from page 6 to page 14. This one is very good.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
How do I pick the perfect pole saw?
Want to saw up high, but think it's dangerous to saw on a ladder? Good thinking. So how can you get your saw to reach those high branches while keeping your feet planted on the ground?
Take a lightweight chainsaw, add a stick, and you get a pole saw.
TYPE There are three types of pole saw. You can choose any one of them based on your requirements.
CORDLESS POLE SAW Cordless pole saws are said to be the handiest pole saw as it removes the hassle of carrying wires and cords during pruning. It operates through a rechargeable battery. But, due to its battery pack, its operation time is very specific. If you want to extend the time for heavy duties, you can use extra battery packs.
One of the best advantages of cordless pole saw is its need for low-maintenance. You would hardly need to maintain its well-being.
GAS POWERED POLE SAW Gas powered pole saws are mostly chosen by the professionals for its heavy-duty bars and chains and have the power to cut huge and large branches with ease. This pole saw can be extended up to 9 inches so you might distinguish its expertise in trimming high rise trees. It is good for regular use. It is heavier than the electric one and noisy also. Despite being heavy, you would not face any problem working with it as the pole saw is easy to balance.
ELECTRIC POLE SAW Electric pole saws are preferred for small branches trimming as it has blades of 6"-10". It weighs about 10 pounds that means you can carry the saw effortlessly. It does not require high maintenance as well. Plug the long extension cord before you start, aim at the branches and begin pruning with this electric pole saw.
More details
Guide on How to Pick the Perfect Pole Saw
Apr 16, 2018 | Garden
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
Mar 15, 2012 | Remington Electric Chain Saw
Wondering what size file to use to sharpen an MCP1510
McCULLOCH MCP1510 is not a good pole saw. You can't easy to use with this pole saw. If you want to find the best pole saw in 2018 go to the https://thebestpolesaw2018.yolasite.com/
Jul 25, 2010 | McCulloch 10" Electric Pole / Chain Saw
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
May 11, 2010 | Remington Electric Pole Saw
Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Jan 07, 2010 | Remington Electric Pole Saw
Power needed to operate?
No. During operation the pole saw will draw 960w. With an extension cord you will have some loses that will kick you to the edge of it's operating limit.
The biggest problem is when you start the pole saw it will draw 2 to 3 times it's running current, putting it at 1920w.
Sorry but no.
Mar 31, 2009 | Remington Electric Pole Saw
Remington Electric Chain Saw  Logo
159 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
