My projector work 10 minutes fine i smell something not right than it turns off when it gets cool it will start to work
  • 5,138 Answers
What is your make and model number it is on back of TV.
Posted on Jan 10, 2010
Won't turn on
How long has it been running, projectors ALWAYS turn off when the overheat remove anything covering the cooling vents and it may have dust inside which will compound the problem.
Solution wait for 5-10 minutes.
Dec 26, 2013 | Epson PowerLite 61P Multimedia Projector
Overheating
Try initialization the High Altitude fan setting in the menu set up. This will increase the cooling capacity and should solve your problem
Feb 25, 2013 | Optoma HD700X DLP Projector
Light of projector is not working
Try to turn off your projector and open it again after 10 minutes. The lamp may be malfunctioning due to overheat. This usually happens when your projector was not turned off properly. The fans inside the projector should slowly cool the lamp inside when turning it off properly causing the projector to be in a standby mode for a couple of minutes before you can completely unplug it.
Mar 07, 2011 | Optoma EX536 DLP Projector
Wonderwall projector has black spot in middle of screen
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
Aug 08, 2009 | InFocus LP70+ Multimedia Projector
LP120 : fan stopped error
you can purchase and replace the blower assembly- part # 505-1917-00. it's tricky, but you can do it. find an infocus authorized service center form their web site to buy it.
Jan 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Projectors
The color wheel sensor is bad.
Jan 18, 2009 | HP VP6310 Multimedia Projector
Projector quit working and started smoking
Unfortunately your motor is toast- it also provides the low voltage for the remote control. Motors are no longer available new so your best bet is to try to find an old projector on the sued market. you can often get them as cheap as free to $25.00. If it's working, just use it. If there are other things wrong but it's motor works, you should really have the identical motor- not all were the same electrically.
Dec 18, 2008 | Kodak Office Equipment & Supplies
CP-S335 popping noise when powering on
Hi Eva
A Projector does'nt like being switched on and off all the time , if you are going to watch a couple of movies - rather leave the machine running all the time - this will also help you to get more hours out of your lamp - and that's a promise.
As far as the noise is concerned - it is most probably just the machine that was not cooled down properly at that stage.
Apr 02, 2008 | Hitachi CP-S335 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
