Question about Manhattan Mini WEBCam
The computer doesnot recognize the web cam.It says USB device not recognized.
  • 103 Answers
The cable connector of your webcam or the internal controller of webcam is not functioning well.
You need to change your webcam.
Some times this webcam may work with other computers.
Thanks
Posted on Oct 04, 2009
What should i do to enable my web camera?
Go to device manager an ensure that the drive is installed and that the device is being recognized.
If the device is recognized install a compatible web cam software that will allow you to utilize the web cam.
Nov 28, 2015 | Computers & Internet
Tip
When installing a Web-Cam make sure your old cam has been uninsulated.
When you set up a new Web-Cam for your computer go under to the computers Start up Key, click the "Computer" button, and you will see a option to pick from. Click "Control Panel" and a list of installed programs, and accessories installed in your computers memory will come up. Find your old Web-Cam under the installed "Device Manager" icon.
Uninstall your old cam, and make sure the New one IS NOT plugged in at this point. After you uninstall the old one, you can then PLUG in the new cam, go back to "Device Manager" and click on "View Hardware and Devices" and your computer should recognize you have new hardware plugged into one of your USB ports, and a balloon should pop up, and Click that ballon, your computer SHOULD read and install the Cam, if not use your "Device Manager" and IF a disk came with your Cam, put it into your computer at this point if you already havent. Your PC should recognize what you are tring to do, and install the Cam. Hope this helps, if not type Web Cam into the search engine in your computers search tab, while under the Device Manager, and it will tell you step by step on how to do lots of things.
on Feb 09, 2010 | Cameras
How can i install a usb web camera
If the web camera came with an installation disk, use the disk to install drivers then plug the web camera in a USB port. The computer should recognize it. If it is properly recognized it will work with all applications that support a webcam (Skype, MSN, Google chat..) If it is not recognized and you do not have an installation software, you should go to the manufacturers web site to download appropriate drivers.
Apr 21, 2011 | Computers & Internet
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
Vista does not recognize my powershot a85 cam .. The error it is giving out when i connect the usb cable is 'USB Device not recognized' . It does not display in the my computer box . any ideas ?
Try this first turn off your computer using shut down or pressing the power button and then unplug it from the wall outlet. Let it sit for about 30 minutes and then plug it back in.
You will not be getting the message 'USB Device not recognized' .
Hope this helps .
Jan 31, 2010 | Canon PowerShot A85 Digital Camera
My webcam did not read of my computer
Sir,
First check the system settings it connected or not. Go to control panel-> system-> device manager check with connection is ok or not. also uninstall the driver and reinstall again.
Thanks
Sep 08, 2009 | A4tech PK5
Computer not recognizing web camera
The only other thing that I would suggest you try to do is (if possible) goto another PC or maybe a friends PC and plug the web cam in. If it does the same thing then the web cam no longer works. If it does work, then you may want to try another USB port on your PC.
Jan 23, 2009 | Logitech Webcam
USB External storage device not working properly
please update the USB Drivers and if that Doesnot Work then Update the BIOS of you Computer from the Manufacturers Web site
Nov 01, 2008 | Dell Computers & Internet
My powerbook g4 won't recognize my external hd or my web cam but it recognizes my ipod.
I am not really sure but i think the Camara and the External Hard Drive have to be compatible with Apple I think so you can use it. An IPOD is made by Apple so thats why your G4 recognizes it. I would just buy like a USB Drive. And also try to download the Drivers also and you can do that by google-ing it that sort of think. Anyways just use a windows based computer Bro its much more efficient. Let me know how it goes alright.
Oct 02, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Manhattan Mini WEBCam Logo
238 people viewed this question
Top Manhattan Computers & Internet Experts
Gareth Cockram
Gareth Cockram
kamal dev  jhalli
kamal dev jhalli
Are you a Manhattan Computer and Internet Expert? Answer questions, earn points and help others
