Question about Smeg DO 10PSS Stainless Steel Electric Double Oven
Grill control knob broken
Far right grill control knob broken. Cannot remove front top control panel to see how to fix it.
  • 1 more comment
  • Anonymous Mar 23, 2014
    Front upper panel removal
    front upper panel removal
  • Ronnie
    Ronnie Oct 31, 2016
    So if I remove the 3 screws under the panel in the top over the panel comes off?
  • 205 Answers
Hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Posted on Oct 04, 2009
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
Both oven knobs have come off and although don't appear to be broken we can't seem to fix them back on properly
First try a layer of silver paper around spindle.
If not satisfactory then try a "No nails" type of clue.
Jun 04, 2012 | New World E90DOa Electric Double Oven
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Jun 22, 2011 | Stoves Ovens
I need to remove the control panel to replace the Function Selector (knob) how do I remove the panel? Thanks
you dont need to remove panel to replace, it literally just pulls out from the front as a complete assembly you may find using the edge of a teaspoon helps to draw it forward without marking the steel use the curved bowl of the spoon against the steel.
if the knob is damaged from heat escaping (melted) make sure you grill with the door closed.
Feb 22, 2011 | Neff B1421 Electric Single Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do I fit a new switch to the grill of my Soves electroc oven model no. 059040414 Type 720EF? Have you a manual?
First, a handbook is available, but I will need an email address to send it to you.
To replace the switch, you have to take the whole oven out of its kitchen furniture housing and then take the top off. ) It is held in place by normal wood screwes) All the knobs on the front panel are pull off/push on and you have to remove them. Once you have the knobs off you have to remove the glass control knob panel. On the lower edge of it at either end you will see two cross head screws going upwards. Remove these. Now the only thing holding this in place are I think three lugs on the top of the glass panel that go up and in to the top of the cooker. With a bit of fiddling, the panel should now come off, leaving you free to access the switch for replacement.
I think you will find that the thermostat pipe will link into the top back of the top oven so this has to be very carefully replaced as well, which additionally may require the back of the oven to be unscrewed.
Best of luck!
Nov 06, 2010 | Stoves 720EF Electric Double Oven
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Because I haven't got a manual, and the oven is slightly worn, I would like to know what the symbol at the eleven o'clock position on the top oven control knob means. There are 2 symbols that appear to be...
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
Dec 10, 2009 | Stoves 720EF Electric Double Oven
Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
4. Reverse procedure to reinstall electronic control.try that
Jan 16, 2008 | Ovens
Smeg DO 10PSS Stainless Steel Electric Double Oven Logo
499 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
