Question about Refrigerators
I have an E2 error code on my Bosch KGU3201GB/01, I have found out that it is a freezer thermistor short circuit - but I cannot locate where this part is - I think it is buried in the insulation at the back and I have found the fridge thermistor but can't locate the freezer one (no arrow marking it) - can you help?
  • culfordltd Oct 05, 2009
    I found the fridge thermistor and dug it out, and it houses the same thermistor that is inside the cabinet and therefore it could be replaced - so why can't I do the same for the freezer one (if I could find it) - can you tell me where to look?
  • 770 Answers
It is buried in the insulation in the back of the freezer. Usually there is paper covering the insulation with an arrow indentation directing you where to start your dig. Since you do not have that , I would start in the center and work out in a circle. Once you have completed your repair, you can fix back with foam insulation and the silver, foil tape.
Posted on Oct 05, 2009
    President:
  • 1,734 Answers
The E2 error indicates the failure of a temperature sensor in the freezer. Unfortunately this is foamed in and cannot be changed. Bosch has modified the main control board for these appliances which bypasses the temperature sensor.
There is no work around for this appliance.
It doesn't just cut out the sensor, it also has new software that performs the defrost in a different manner.
However for a 12 yrs old machine the replacement board may be expensive at £140.84
Posted on Oct 04, 2009
Errorcode EE in display. Whats wrong?
E1 - Freezer thermistor open circuit.
E2 - Freezer thermistor short circuit.
E3 - Fridge thermistor open circuit.
E4 - Fridge thermistor short circuit.
E7 - Evaporator thermistor open circuit.
E8 - Evaporator thermistor short circuit.
E9 - Temperature set switch open circuit
EA - No feedback from Baffle
EB - Fridge Baffle motor operating continuously
EE - Defrost time out
This was the only code listing with an EE error code - which is a Hotpoint - so if your's isn't a Hotpoint it is probably incorrect.
If you do have a Hotpoint Refrigerator then either the defrost timer is not functioning correctly or your heater element is malfunctioning.
Jun 20, 2011 | Refrigerators
Tip
Whirlpool Calypso Dryer Error Code Explanations And Repair
Failure - Code Condition - Check/Repair
PF - Power Failure - If the household power goes off and the control board was in RUN mode or PAUSE mode, the electronic control board will display a power failure error code.
E1 or E2 - Thermistor Failure - The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
  • When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
  • When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
  • 60 degrees F. - 15.3K ohms.
  • 70 degrees F. - 11.9K ohms.
  • 80 degrees F. - 9.2K ohms.
E3 - Touchpad or Software mismatch - Flashes when there is a touch pad or software mismatch.
  • This error code is displayed only in diagnostics mode.
on Jul 19, 2010 | Washing Machines
Dryer not working. failure code E2
The electronic control board detected that the thermistor located on the blower housing is shorted (zero resistance). Either the wire harness connecting the thermistor and the electronic control board has a short circuit or the thermistor is indeed shorted. Click on the link below for the detailed troubleshooting instructions of this problem.
Troubleshooting Error Code E2 on Whirlpool Duet Dryers
Mar 01, 2011 | Whirlpool Dryers
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
E-1 CODE
Hello there
This code can sometimes be the e-1 or sometimes the e-2 here is the descrioption of what it means
80 degrees F. - 9.2K ohms.Dryer thermistor assembly
Jul 27, 2010 | Whirlpool GEW9200L Electric Dryer
Code E1
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
E1 code on kenmore front load dryer
Hello there
I have written a list of codes that should cover your problem nd give you some idea what to check ok
80 degrees F. - 9.2K ohms. E3 Touchpad or Software mismatch Flashes when there is a touchpad or software
Dec 16, 2009 | Kenmore Dryers
Whilpool stove gives errorr message . E1-F2 want come on model# G W395LEpB00 SER# XD3802931
F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Nov 23, 2009 | Cell Phones
E2 fault on Bosch kgu3201
Dear Sir,
It's a thermistor error, the internal evaporator one... but disconnect the fridge and freezer ones first in turn to see if the error changes. If it is the internal one, you should see an arrow impression on the paper covering the insulation which marks the spot to dig(at the back of the freezer.) Usually this error occur when water ingresses the push on tags, shorting out the thermistor.
Now the bonus... 9 times out of 10, you don't need to buy a spare, as there will probably be nothing wrong with the error giving thermistor. Remove and fit the fridge thermistor in the place of the internal one... clean and dry the internal one you removed and refit it inside the fridge.
You will need to repair the insulation with two pack brown foam insulation and foil tape. deffinately this solution solves your problem.If you have any problem regarding this issue post comment more information about the problem.we will glad to assist you
good luck.
good luck
Aug 26, 2009 | Bosch Refrigerators
Dryer stops soon afetr cycle starts, E1 appears
ensure lint trap is clean and venting is not restricted or blocked.
Feb 10, 2009 | Whirlpool GEW9200L Electric Dryer
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
