Question about Garden
I have a brand new Boomag chain saw from berlin. a 25cc engine with a 12'' bar.started it up first time but wasn't idleing right when reving it up. completed 3 cuts with it and went to put it down but it didn't idle it kept reving. after switching it off it now won't start. have sent one back previously with diffr=erent problem and it took about 4 weeks to arrange pick up and drop off so dont won't to go through the hassel again. have tried idle screw but no luck. i'm a joiner not a mechanic...
  • 10865 Answers
SOURCE: Chain moves while idle
Hello there. Regarding the bar oil, many loggers plan their work so that they are out of bar oil at the same time that they quit for the day because bar oil has a tendency to leak. Another method that has some success is to mix your bar oil with a heavier oil but the trade off might be less lube getting to the chain when you need it.
Regarding the chain moving in idle, this is another common problem. You can usually slow the idle down until the chain stops, as you indicated, but I too have had chain saws where I finally just decided to live with it and be extra attentive to what was going on.
Posted on Jun 11, 2009
  • 135 Answers
SOURCE: while cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Posted on Jan 02, 2010
  • 20 Answers
SOURCE: john deere chain saw CS 56 idle adjustment
check the choke lever rod possable loose or off
Posted on Feb 11, 2010
SOURCE: I bought a couple of boomag 58cc chainsaws but the
I had a similar problem, took mine to a car mechanic and he was able to fix it, no problems so far. Do you know where i might get the manual for this Boomag 58cc model? Cheers
Posted on Jun 28, 2010
  • 11 Answers
SOURCE: Chain saw starts fine, idles fine, and powers up
Two things that can cause this problem. 1. Your carburetor is not set properly and is not letting the engine get enough fuel under a load. 2. Your chain is binding when you put the chain bar down on the log. Make sure your front chain sproket is turning free and is not too sloppy.
Posted on Sep 13, 2010
Brand new stihl ms 170. started ran for 5 min chain came off. stopped put chain on and it won't turn. chain won't slide through the guide in the bar. what is the issue and how do I fix it
if the chain wont slide on the bar id say the bar is damaged now. always check chain tightness before using any saw and make sure you have plenty of bar oil too.
Sep 24, 2017 | Stihl Garden
Brand new 25cc. baumr au sx25 chain saw wont start.has spark , fresh fuel ,even tried ( start you b. ). Not even a kick. I have tried on about 6 or 7 different days with no success ?
take it back in for a warranty check as it is brand new
if it has a primer bulb then press it sparingly as the will flood the carby very easily
pull the plug , hold the throttle wide open and pull the cord a dozen times to remove excess fuel from the crankcase
Apr 28, 2016 | Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
My chain keeps freezing up on me and its brand new. how do I fix tha t on my husqvana 16 inch
Turn the chain brake off, then remove the bar and chain. Clean the side of the engine where the bar fits to, start the engine and observe whether the small oil port on the engine oozes out oil. If nothing and the oil tank is filled, put the saw back together and take it back to the seller for warranty repair of the oil pumping system or a fresh saw in exchange. Hope this helps!
Dec 21, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a brand new German made Boomag 58cc 20" chainsaw and am having trouble attaching the blade arm to the engine. I loosen the two bolts but the cover attached to the chain stop bar won't come loose. I...
Make sure the chain brake is released. Remove the two cover bolts completely and back off the chain adjustment screw several turns. All of this should release the cover. Make sure the chain teeth cut toward you on the bottom run. When adjusting the chain, leave the cover screws finger tight, and turn the adjusting screw CW to bring the chain up to the lower bar run, but not so tight that the chain cannot be moved by hand. Tighten the cover screws and recheck chain tension. When running, hold the bar tip near some cardboard while running at speed--it should throw off a thin line of oil onto the board. Hope this helps!
Jun 28, 2010 | Garden
I have a McCulloch Mac 110 mini-Chain saw that needs a new chain blade. I believe it's a 12 inch... anything else I need to know to go buy a new bade?
Hello Kip;
If the new bar is not the same size as the old chains will not fit. Count the drive links on your chain.
If your 44 your bar is 12", if your 49 your bar is 14", if your 54 your bar is 16" and finally if your 60 your bar is 18". If not of the following your chains will need to be professionally resized to fit (select 110 not Mac110 please).
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
I seriously doubt you saw needs an "Intenz" bar.
The Oregon part number you choose can easily be converted to a different bar manufacturer's part number.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 25, 2010 | McCulloch Garden
Lost manual need to know what kind/weight oil does the Remington 16" chain saw require?
Any good quality chain saw 'bar' oil is suitable and it does not need to be an expensve brand either: it is highly recommended that you use a specially blended chain saw 'bar' oil but in emergency you can you fresh 'thick' (e.g. older) car engine oil but don't make it a habit as your chain and bar will wear off a lot faster!
Mar 06, 2010 | Remington 16" Electric Chain Saw Assembled...
I bought a couple of boomag 58cc chainsaws but the pullcord and springs broke can anyone tell me where to get boomag saw parts .I cant find anyone who knows where
Jan 29, 2010 | Garden
Where do I find a replacement chain for my McCulloch Eager ****** 2318av chain saw (model # 600038-12)?
Your friendly neighborhood chainsaw shop can fabricate one in about 5 minutes. Take your existing chain for use as pattern.
McCulloch.com
http://www.ordertree.com/modelinfo/MCC/11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318/139.11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318.1.59.1.html
If original 18" bar.
part number(pn) MCC 21927533
Oregon Bar & Chain Selector (again original 18" bar)
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your saw with 18" bar returns
Oregon pn 91VG060G.
This can be easily crossed to other manufacturers chain. You might consider a more aggressive chain (dependent on your level of expertise). HTH
Lou
Jan 20, 2010 | McCulloch Garden
I have a MAC 3516 and need a replacement bar and chain. The original Chain and bar are not available. the saw runs good but need the primer bulb and chain bar and chain. Any ideas would be great.
Hello Eric, You can get an Oregon brand bar and chain that will work perfectly on your Mac 3516. I have this same chainsaw and keep a spare bar and chain, so I can quickly swap them out, should they get damaged, etc.
The Oregon bar and chain part numbers are as follows:
#100457 (Bar & chain combo pack)
You can also find these sold at most Home Depot, Lowe's and other hardware stores that carry chainsaws, as Oregon makes their replacement bar and chains to fit all the major brands available.
Unless your existing bar and chain are completely galled up, scored or bent/busted beyond repair, I would find a small engine repair shop or local hardware store that sharpens chainsaw cutting chains, (True Value and Ace do it in our area) and see if they can sharpen and true up the bar. The price for this is typically about 1/3 to 1/2 the price of a new chain and bar set, and worth having a spare around.
I also like having that extra aleady to use (sharp) chain, so when a neighbor borrows my saw and invariably lets the chainsaw go into the dirt (that'll dull the chain so fast!). I will always be able to use my saw, when I need to, without having to run out and get a replacement, or spend 15 minutes having to sharpen it by hand, etc.
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | McCulloch Garden
Garden Logo
1,810 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
