Question about Zanussi 24 in. ZSF6120 Free-standing Dishwasher
Does not appear to be heating up - Zanussi 24 in. ZSF6120 Free-standing Dishwasher
    Problem Solver:
  • 4 Answers
Hi Deb the most obvious initial solution would be to check that the wiring which feeds the element is still connected and has broken off or worked loose due to usage,make sure the machine is balanced correctly also to prevent this occurring again if it is the problem,the other possibility initially would be to have the element checked in case it has burned out as its a Zanussi either one of these is a strong possibility as they are very well made
Regards JL
Posted on Oct 04, 2009
My heating will not switch off. The 'heating on'
I have the same problem . Did you fix it ? P Hayes
Mar 31, 2010 | AT&T Siemens S46 GSM Cellular Phone
Dryer appears to work but there is no heat. i
Check the heating element and the thermal fuse. If you have an ohms meter test the two for continuity.
Jul 04, 2009 | Dryers
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
Jun 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Water level below heating element and element does not appear to heat
Make sure the drain hose high loop is installed properly, normally you have this in the sink cabinet high up. Otherwise the water inside the machine may drain "by itself", leaking through the inactive drain pump during the wash cycle and cause this and other troubles.
May 24, 2009 | Kenmore Dishwashers
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Appears normal
ya this is the same problem i too had...everything will seem to right but the part required for heating might be damaged internally...try changing tat...here i did the same...
Sep 19, 2008 | Frigidaire GLMV168K Microwave Oven
Microwave appears to work fine but will not heat at all.
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Feb 04, 2008 | Thermador MBBS Microwave Oven
Zanussi 24 in. ZSF6120 Free-standing Dishwasher Logo
298 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
