My bosch washing machine door opening button is broken
  • 50 Answers
If it is just the plastic part use some glue to stick or if the clamp or some connectivity is broken then change the set from service station.
Posted on Oct 04, 2009
My Bosch AvantiXX front load washing machine has finished the wash and now it has locked on me and I can't open it. How can I open the door?
hi Suzanne.
i have had a look around the internet and found that there is lots of ways to try and open it.plus there is people on youtube showing how to open a door.
so if you go to this link and pick the one you think would be the best one for you to try.
Bosch AvantiXX front load washing machine door wont open Google Search .
or this one.
How to open washing machine door that won open normally
Nov 20, 2017 | Bosch Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Bosch exxcel 7 have E43 code flashing I can open the door ok and washing Is wet any clues?
drum motor does - REMANENT ERROR - speed sensor is broken - Reset error with activating Normal mode not rotate - washing program is aborted - drum is blocked by laundry test mode Pos.3 Motor - door is unlocked, if possible - motor is blocked - check control - operator control actions are blocked - control is broken - the current indication is frozen ? Triac is broken
Feb 13, 2016 | Bosch Washing Machines
Bosch Maxx6 washing machine. Shut door,rinse button flashing but door not lock so start button will not start circle
look at the place where the lock locked in the door the metal pinns could be broken or covered with erosion or something. De door lock makes no contact with the receptor.
Mar 04, 2015 | Bosch Washing Machines
Door open
most likely if the door was removed the button or lever that signaled it was closed has fallen out or broken off.
Jan 10, 2014 | Washing Machines
Washing machine door leaver is broken
Get a new one from you bosch service agent You will need the model number for this. If you can't replace it your self you might have to pay for a service call
Mar 24, 2013 | Bosch Washing Machines
The door on my Bosch washing machine 1605 is stuck on shut
Hiya,
the door not opening is normally a sign that there is still water inside if you can try a spin cycle or if you have a drain option try using that & if it was the water then the switch will trip & you should be able to open the door again.
Hope this helps
Apr 21, 2010 | Washing Machines
My Bosch WFF 2000 washing machine goes through its cycle and then leaves the on/off button lit, the door button lit and the pre-wash button flashing; also the door will not open until you turn all the...
The problem turned out to be foreign objects in the pump that stopped the machine from draining; the solution is simply to open up the pump and remove the objects!
Sep 09, 2008 | Bosch Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
