Related Tags:
This problem should be removed because:
Problem with Kenwood VR-209 Receiver
VR-206 - how to wire in equalizer
How do I wire in an equalizer with a Kenwood vr-206. I suspect I want to take the pre-amp out, run this signal through the equalizer, and then bring the signal back into the VR-206. Which jacks on the back do I use for these functions?
Solutions (1)
your vr-206 have several inputs dvd, vcr, tape decks, turn tables etc, also have an opcion called eq in and out usually if you dont have an equalizer al you do is jump straight rca to rca cables red in to red out and white in to white out.
but if you have an eq all you do is output from amp vr-206 to input and the input to output back to the amp
Kenwood VR-206
I think the power transformer is bad. I have a Kenwood VR-206. Should I buy another receiver or should I fix what I have?
Can I Get a Kenwood RC-R0608 Remote to work with a...
I Bought a Used Kenwood VR-206 audio/video Surround Reciever but it was missing the remote. I have a Kenwood RC-R0608 Remote, Is there...
receiver works with digital signal input jack...
Kenwood VR-405 receiver. I get little or no output from rear RCA jacks all source inputs... full volume and sound level is barely...
I have a VR-407 reciever
I have a VR-407 reciever and I am unable to get my CD/DVD rear outputs to work. I am hooking up a DP-3020 and I can get it to work in the...
Add Your Solution
Does a Kenwood Remote RC-892 work for a Kenwood...
I have a Kenwood receiver VR209 and need a remote that works it for volume, cd, tape, phono, surround, etc.What kind do...
when i turn on my kenwood reciver on it turns back
when i turn on my kenwood reciver on it turns back off and the standyby light strarts to blinking..wat do i do?
Hi I have the VR-209
Hi I have the VR-209 reciever. I only have bass out of one speaker. I swapped speakers and still the same problem. I was...
Fix-O-Meter
127
127 people viewed this problem
- 0 people are following this problem. Be the first!
Top Kenwood Receiver Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
