Question about LG VOYAGER VX10000 Cellular Phone
I droped my voyager in water - LG VOYAGER VX10000 Cellular Phone
    President:
  • 570 Answers
Http://www.fixya.com/support/r3771170-phone_water_damage
Posted on Jan 08, 2010
    President:
  • 267 Answers
HI,
if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. This reduces the risk of a short circuit which would render your phone useless. Dry the batter with a towel and set aside to dry thoroughly.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits.
If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately.
Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open for maximum evaporation.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath.
The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If drop your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
PLEASE USE HAIR DRYER TO DRY IT AND DONT CHARGE OR SWITCH IT ON FOR A DAY....................................
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
My phone droped in water , seperted the battery from cellphone, 2 days latter all it show is charging but wont come on?
take phone apart and put all pieces in rice for 24 hours it will suck out any moisture
Mar 22, 2013 | Cell Phones
Check engine light is on engine is missing and fuel mileage has droped 4 mpg where is connector for 95 ply grand vog
OBD 2 connecotr is usually under dash on driver side. But OBD 2 did not start officially until 1996.
OBD 1 before that. Could be under hood.
Jun 24, 2011 | 1995 Plymouth Voyager
Nokia 1650 set on but no function still light on otherwise not set re off
Dear customer
If your mobile was droped by you or it is drown in water then open it by T-6 screw driver with vary carefully.Open your mobile and check it and wash by toothbrash with PCB cleaner and give some hot air by hecco machin.If it is not droped or drown in water then FLASH your mobile by softwere HWK flasher with new version
May 21, 2010 | Audiovox Bosch 718 World Cellular Phone
Talkabout T5800 (22 Channels) 2-Way Radio: droped in water will not transmit but will receved...
Depending on the type of microphone used, if not the type using the speaker as a microphone, it may be damaged. I would though, suggest you remove the battery, open the case and allow the innards to dry in a warm place for several days. Even daily exposure to the sun should work fine.
May 16, 2010 | Motorola Talkabout T5800 (22 Channels)...
Slow Leak in Water Pump-1999 Plymouth Voyager
What's probably happening is the weep hole on the water pump is leaking water. The weep hole is a warning sign that the water pump needs replaced. You don't have any heat because the impeller in the water pump is no longer circulating water.
Apr 23, 2010 | 1999 Plymouth Voyager
I accidentally droped my ipod nano 4G it truns on
well renda, when you drop an apple ipod nano 4gb mp3 player in water its bound to stop working even if its new so get a new one would be my solution.
Mar 01, 2010 | Apple iPod nano
Radiator water level keeps on droping
You coolant system needs to be pressure tested to determine a possible leak or intake gasket problem. The radiator and reservoir caps as well.
If that all checks out ok...then a cylinder compression leakdown test is advised.
Good luck...i hope this helps..please rate me a fixya
Jul 29, 2009 | 2000 Mercedes-Benz C-Class
Droped my phone into water while back trying to fix it now and goes to blue screen and says bootloader usb init
if you did not take the battery out as soon as you pulled it out of the water it is probily no good because the circuit board was fried from the electric current that the battery was feeding the phone. but for future ref. if droped in the water remove batt asap and take phone apart and dry with a q tip and put back to gether and let it sit for a bout a day to let all the water get out of the phone and then place the batt back in it and turn it on.
Feb 20, 2009 | Motorola Mobility RAZR V3
94 Plymouth Voyager Water Pump
thw water pump stuff you need is here
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280215d73
The heater stuff is here
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280216054
Hope this helps! good luck!
Sep 15, 2008 | 1994 Plymouth Voyager
LG VOYAGER VX10000 Cellular Phone Logo
133 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
