Question about Candy Dishwashers
Candy dishwasher CDl 1012/2-80, program stuck?
Candy dishwasher CDl 1012/2-80, newly fitted only used about 10 times, the first 4 program lights come on when on/off switch is pressed, bleeps for about 10 seconds, all 4 lights stay on, program button does not work, if door is closed the pump startes for about 30 sec, then stops, its acting as if its stuck halfway through a program. help please
  • derek_gargan Oct 06, 2009
    Hi, thanks for advice, it was the first thing I tried, but as I bought the dishwasher in one terrotory and moved home almost immediatly (machine still unused)the guarantee is not valid unless I take it back to the purchase area. That would cost me the same as buying 5 new ones.
    Problem Solver:
  • 4 Answers
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Posted on Oct 04, 2009
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Where can I buy new loading baskets for my DWI 160 dishwasher?
These come as several parts. Not sure if all are available anymore as Candy parts. But you can get replacement Hoover parts to fit.
Main basket from Candy
Candy DWI 160W UK Dishwasher Basket
Cutlery basket from Candy
Candy DWI 160W UK Universal Cutlery Basket
The Upper and Lower baskets may not be available from Candy but Hoover replacements are
Candy Use HVR41022779 Lower Basket
Best to ask Candy support to provide pictures of the parts for comparison with your model or purchase or a refund policy if not suitable.
There is another site worth checking (but prices seem high)
CANDY DISHWASHER BASKET LOWER for DWI160W UK
Sep 23, 2014 | Candy Dishwashers
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
My dishwasher get stuck after the pre rinse with both lights ,the pre rinse and wash lights flashing,failing to go to the wash programe.
It is likely the drain pump or hose is blocked.
It might be helpful if you can provide the full model number of the candy dishwasher.
Dec 12, 2010 | Candy Dishwashers
CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Feb 22, 2010 | Candy F248P Electric Single Oven
Candy dishwasher 2 program lights keep flashing after program starts then stopas and flashing starts
My candy dishwasher Model No CDI 3015-S retains water in the bottom of the machine at the end of the program. I have checked the filter which is clear so do not know what else to do to clear the problem. Anyone faced this problem or know what might be the cause?
Jan 18, 2010 | Candy 17 in. CS455 Built-in Dishwasher
My candy dishwasher CSD68-80 rinses but then the rinse and wash light come on together. Nothing happens after that.
I checked all filters which were ok. Put bleach into the place for salt. I know this was a risk. Switched it off overnight and it worked perfectly the next time I used it.
Aug 01, 2009 | Candy Dishwashers
Dishwasher wont complete program 1 2 or 3
Did you ever resolve this problem with your dishwasher, unfortunately i've exactly the same type of problem!
Thanks Steve
Dec 18, 2008 | Dishwashers
Candy
"e" is economy wash and the other buttons are temp selection. i suspect that the problem may be the spray arms not rotating. open bthe door when on wash and check the arms are rotating. if not, remove the arms and clean - they tend to get blocked over a period of time. the arms only rotate with water coming out of angled jets at the end
May 18, 2007 | Candy 24 in. CD950 Free-standing...
Dishwashers Logo
826 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
 Evgeniy_Getz
Evgeniy_Getz
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
