Question about Rosetta Stone V3 English (U.K.) Level 3 Personal Edition (Win/Mac) for PC, Mac (1580228348)
Can not connect to the manager server from client
I have a server which has the rosetta stone manager application installed , and a few laptops that are having the network application installed , although i can ping the server manager from the laptops , when trying to open the application from the laptops , i get ''7112 connection to the rosetta stone manager server failed'' , no firewall is enabled !
laikexpert
  • 281 Answers
SOURCE: Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Posted on Jan 04, 2010
  • 10 Answers
SOURCE: rosetta stone won't recognize my logitech headset
Make sure that your device is set as your default device by making sure that there is a green check mark next to the device. If not, right click and select "set as default device" (or something like that... I have vista and not win7)
If that does not work, right click on the headphones and go to "Properties" then go and under the "General" tab, change the name of the device to "Microphone HS" For some reason, Rosetta Stone does not recognize the headset unless it has the word "Microphone" in its name... Kinda stupid if you ask me. Hope that helps...
Posted on Mar 03, 2010
SOURCE: When I try to run Rosetta Stone Network Version 3
I was able to resolve this by turning off Windows Firewall.
Posted on Mar 18, 2010
customers184
  • 154 Answers
SOURCE: Cant get it to install. Any time i open the
What you may need to do is to first remove the software.
Go under your control panel and located "Add/Remove Programs"
Find the software and do "Uninstall"
Once the uninstall process has run, then restart your computer.
Once your computer has restarted, prior to installation review the system requirements on the back of the box of the software or look for a link online. This will ensure that there isnt a memory requirement which your computer or processor is not meeting.
Once you have ensured that your computer meet the basic minimum requirements, then being installation again. If there is still issues, then I would ask for the another CD and also for technical help from their help desk or customer suport.
Posted on Dec 07, 2010
SOURCE: My Japanese Level 1 stopped
Uninstall/Reinstall Rosetta Stone Application.
Check this link (How to uninstall or change a program)
Uninstall Flash player..check this link ->here
Get adobe flash player->click here
Then reboot your PC.
Posted on Apr 06, 2011
I got a Error 4118 with my Rosetta Stone program
Go to the Rosetta Stone website. They have some solutions posted for this problem.
Dec 27, 2014 | Rosetta Stone Computers & Internet
Error 9119 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure. Good luck and spread the word.
Dec 05, 2013 | Rosetta Stone V3 Spanish (Latin America)...
Error 9119, 9114 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
Dec 29, 2012 | Rosetta Stone Computers & Internet
I CURRENTLY HAVE ROSETTA STONE INSTALLED ON A SEPARATE LAPTOP AND I AM TRYING TO INSTALL IT ON A BRAND NEW LAPTOP DO I NEED TO REMOVE IT FROM THE OLD LAPTOP BEFORE I CAN INSTALL AND ACTIVATE ON MY NEW ONE
Rosetta is one of the few software companies that has excellent technical support. I would suggest calling the support number and explaining the problem to them. When I did this with my installation, they were able to deactivate the old computer and authorize the new computer within a few minutes.
They were also able to give me instructions on how to copy over my old progress files so I didn't have to start the lessons from scratch.
Jan 15, 2011 | Rosetta Stone Spanish (Latin American) -...
Error 2123 appears when loading rosetta stone
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
Feb 20, 2010 | Rosetta Stone Japanese Level 1 & 2 for...
After uploading the application software for Rosetta Stone, I try and start the application and I receive: there was an error in the application. error 2123. How do I fix this problem for my iBook G4...
Feb 02, 2010 | Rosetta Stone Spanish Spain Level I & II...
There is an error with this application
Nov 23, 2009 | Rosetta Stone V3 Spanish (Latin America)...
I have Japanese levels 1,2 and 3 for rosetta stone. i installed all the software and entered the activation code. it says my codes are activated but when i open the software i only get a blank screen with...
The problem is related to the FNPLicensingService.exe service and FNInterface.dll file.
The first thing you can try is open Rosetta Stoneto and kill the FNPLicensingService.exe in task manager. This may or may not give you access to Rosetta Stone.
If that doesn't work, install Rosetta Stone on another computer (your license will allow two machines) then copy the rosetta stone directory from program files to the new system. Then open Rosetta Stone and it should be fine.
Before doing either of these things it's best to delete the c:\program data\rosetta stone\tracking.id file.
Aug 06, 2009 | Rosetta Stone Japanese Level 1 & 2 for...
Rosetta Stone V3 English (U.K.) Level 3 Personal Edition (Win/Mac) for PC, Mac (1580228348) Logo
962 people viewed this question
Top Rosetta Stone Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jax Planet
Jax Planet
IT GURUS OF ATLANTA
IT GURUS OF ATLANTA
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
