Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Lens produce sound
When i turn on or turn off the lens will produce a shriek sound.
Maytag Model SDG3606AWW slow to start, shrieks when running
T"he sound you are hearing is coming from the blower wheel.This is located in the front of the machine and can be accessed by removing the front of the machine, Getting the front off varies machine to machine, Once the front is off, you'll see the blower wheel in the front, and once again some models you may have to remove exhaust vent, in others just the cover of the blower wheel. This is an easy repair, no doubt. The part number is 56000
Jun 03, 2012 | Maytag Dryers
SHRIEKING SOUND WHEN THE CAR IS TURNES ON
Sounds like the starter motor is staying engaged with the flywheel momentarily, You will probably need to eventually change it. Hope this helped...
Mar 10, 2011 | 1997 Nissan Maxima
Droppped it about one foot W/ lens out, now lens won't retract and camera turns off as soon as i turn it on. the lens sounds like it wants to retract but doesn't.
The gear is misaligned and will need to take apart to fix. Do not force since this will further produce more problems. Take it to a camera shop to fix. However, you might get charged alot of money, so I recommend getting a new camera -since they're now getting cheap to buy.
Nov 01, 2010 | Kodak EASYSHARE V1253 Digital Camera
My camera lens won't go back in and is making weird noises.
Since you said it makes noise when you turn it on, the gear system controlling the lens might be faulty. have it checked.
Sep 16, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Shrieking Lawnmower!! I hit small tree branch w/ walking non-drive 3.75 hp Briggs and Scrap-Iron "Sprint" off-brand gas mower. Started shrieking like banshee. Resulted in tangled pull-cord. So I removed...
sounds like you have dirt in the recoil clutch, (under the screen) or you bent something there. try removing the clutch and make sure shaft is very clean and lightly coated with oil. This would be for a briggs and stratton engine.
Jul 25, 2009 | Garden
My new 400D with kit lens produces dark pictures. I tried everyth
take it back and get it replaced sound like your shutter Assembly went out.
Jan 06, 2009 | Canon Digital Rebel / EOS-300D Digital...
Shrieking clutch 1996 mustang gt
Probably a throw-out bearing, also called a clutch release bearing. It will eventually have to be replaced, and sooner better than later. If it freezes up completely, you can do some damage to the clutch assembly or release arm.
Jul 26, 2008 | 1996 Ford Mustang
L MARK shrieking noise
No, do not spray oil on your belts. Have the belt replaced if that's where the noise is coming from. The squeaky belt could also indicate one of the accessories may be bad. Have who ever replacing the belt check to make sure all the accessory pulleys turn freely.
May 14, 2008 | 2005 Lincoln Mark
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
