Question about Samsung SGH2100SGH600V300 Unlock/Unlocking Code/Codes Cellular Phone
Keypad on top half of phone will not work.
SGH-J750. Keypad on top half of phone will not work. The navigation circle, the 'OK' button, , the 'c' button, the call button, the two top right & left buttons, none of these works. The phone is able to be turned on using the decline call button thing. Is there a way to fix this? Earlier this week I was having problems with it, and I removed the battery and put it back in, it worked fine. Earlier today, I tried to use the buttons and they would not work. I got limited usage out of them, as I turned the phone off multiple times & at one point had the top left button that is used to select things working, which is what I really wanted, but now it doesn't. Then I had the 'OK' button working. Not anymore. Now nothing works except the button that turns the phone on or off. Please help, this is unbelievably frustrating & has been going on for a week now.
Thanks.
Screen goes white and cant press the C or OK buttons
Yes you have to .The strip inside is a common problem on the samsung sliding phones
Jan 10, 2010 | Samsung SGH-J750 Cell Phone
How do I replace the key pad on my sgh-Jj750 without sending it in to a shop. Thanks Handy man
Take the battery out and you will see four screws.Unscrew them and remove the top cover.Be carefull not to break the clips.Lift it slightly and the keypad will be loose.Replace the keypad after lifting with you finger.Then clip back and close the lid
Oct 11, 2009 | Samsung SGH-J750 Cell Phone
No power button on Samsung SGH-J750
Try Connecting the Charger. Sometimes that will turn the phone On. No Guarantees it will work though, just a thought.
Jul 01, 2009 | Samsung SGH-J750 Cell Phone
My phones keypad is locked
THIS IS A SLIDING PHONE,WHEN YOU SLIDE IT SHUT IT LOCKS THE KEYPAD,TO UNLOCK KEYPAD PRESS THE POWER ON/OFF BUTTON ONCE ITS THE BUTTON WITH A LOGO ON IT THAT LOOKS LIKE A CIRCLE WITH A LINE GOING THROUGH THE CENTRE
Mar 11, 2009 | Samsung SGH-E900 Cellular Phone
How do i change the keypad tone volume or switch it off
on the left side off the phone there should be a slider button press on the arrow that shows down and it should show you a volume meter on the display keep pessing the down button until you cant hear any more sounds from the keypad.
Jan 25, 2009 | Samsung SGH-J750 Cell Phone
SGH-J750 phone
you should be able to go into the phone settings and unlcok the keypad lock.
May 23, 2008 | Samsung SGH-D900 Cellular Phone
Keypad settings
the only options Ive found for this are if you hit a button with the slider closed it asks if you want to unlock the keypad. Then you hit the right top button (says "ok") and it unlocks...this stays like this until you open and then close the slider. This is the only way I know of to unlock the keypad, I have not found any other way in settings menu or anywhere else. Good luck!!
Dec 20, 2007 | Samsung SGH-t629 Cellular Phone
Top half of phone not working
there is problem in your keypad, so contact lg care center. and also check u r phone battery
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Samsung SGH2100SGH600V300 Unlock/Unlocking Code/Codes Cellular Phone Logo
105 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
