Question about Boating
How do I seperate the steering cable from a Mariner 75 outboard engine.Inner cable has come away/snapped inside the steering tube on the engine and the outer sleeve will not come out all the way. How is the cable attatched inside the tube
  • 677 Answers
These things are a one piece item.You have to replace the entire cable.From the steering end to the outboard end.From the info you gave me this is all I can tell you.Hope this helps
Posted on Oct 04, 2009
Proper Maintance program for 1986 mariner 150 hp 2 stroke boat motor
The biggie is changing the lower unit oil,, making sure its not getting water inside,, R&R the fuel filter, R&R spark plugs, grease all fittings.. DOUBLE check the steering cables... they rust and corrode from the inside...NOT fun to be in a boat when the steering cable breaks!!!!!
Mariner Outboard Service Repair Manuals by Seloc 1977 2004
Jul 08, 2017 | HP Boating
What year and model is mariner 75 serial number 9502368
Hey Arthur,
This serial number does not show up..???Please look for more numbers on any plate or freeze plug..
These guys can help.. need more info though...
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
Jun 20, 2017 | Boating
Steering gear
Hi Alfred.
Your answer will depend on the fishing boat.
For really small boats, with an outboard motor on the back, the motor will be on a pivot joint, and have a handle in front. You point the running motor side to side to steer the boat.
Larger boats with outboards will have a steering wheel with a mechanical linkage to an outboard motor or motors that will pivot them side to side to steer.
Larger fishing boats, especially commercial boats, will have an inboard engine and prop shaft, a fixed external propellor or propellors, and a rudder that is connected with a mechanical linkage to the steering wheel or ships-wheel to move the rudder side to side and steer the boat by deflecting how the water flows by when under way.
Hoping this helps.
D
Dec 16, 2015 | Boating
Why does my mercury outboard idle perfectly but stall out under load?
Your carbs are probably dirty. Remove the carbs and clean out all jets and passages with carbcleaner and compressed air.
Nov 13, 2014 | Clymer Mercury/Mariner 75-275 Hp...
1987 Mercury 75 hp 2 stroke outboard motor clicks when we try to start it
Do you mean it clicks and starter not turning ? if yes then the starter solinoid wires are loose or it needs replacing ! more info needed !
Aug 16, 2014 | Clymer Mercury/mariner 75-275 Hp...
75 horse power ercurywhat year of manufacture serial number 06255293
There is no data included in the serial number that gives info of what year the engine was made. You can, however look up the number here, and that will tell you the year of manufactor.
http://www.iboats.com/basics/serial_number_year.html#mercury
Aug 15, 2014 | Clymer Mercury/mariner 75-275 Hp...
Why won't my mercury marine engine not restart after running for 30 or 40 min.
is it cooling ok ? run on hose and check engine block and exhaust plate cool ! water inlets clear and impellor good condition ? compressions all over 100psi ? carbs clean ?
Jul 23, 2014 | Clymer Mercury/Mariner 75-225 HP 4-Stroke...
How to replace 2002 pt cruiser starter
2.4L Non-Turbo Engine
Remove or disconnect the following:
Negative battery cable Air cleaner box cover Engine structural collar Starter electrical connectors Starter To install:
  1. Install the starter and torque the bolts to 40 ft. lbs. (54 Nm). Attach the starter electrical connectors.
  2. Install the engine structural collar on models with a automatic transaxle as follows, refer to the illustration for bolt locations:
    1. Place the collar in position and hand tighten the collar to transaxle bolt.
    2. Position the power steering hose support bracket and install the collar to oil pan bolt.
    3. Place the bending strut in place and hand start the bolt.
    4. Install the bolt through the strut and collar and hand tighten.
    5. Place the power steering hose support bracket in position and install and hand tighten the remaining bolts.
    6. Tighten the collar-to-transmission bolts to 75 ft. lbs. (101 Nm).
    7. Install the bolts through the strut and into the block.
    8. Tighten the remaining bolts to 45 ft. lbs. (61 Nm).
  3. Install the engine structural collar on models with a manual transaxle as follows, refer to the illustration for bolt locations:
    3. Position the clutch slave cylinder into position and hand start the bolts.
    4. Tighten bolts (1) to 75 ft. lbs. (101 Nm).
    5. Tighten bolts (2 and 5) to 45 ft. lbs. (61 Nm).
    6. Tighten bolts (3 and 4) to 20 ft. lbs. (28 Nm).
  4. Install the air cleaner box cover and connect the negative battery cable.
2.4L Turbo Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Air cleaner box cover Upper starter bolt by pushing the inner cooler up and out of the way Inner cooler lower hose from the inner cooler Nuts retaining the inner cooler tube Studs retaining the power steering lines Position the power steering lines aside Engine structural collar Starter electrical connectors Starter
To install:
  4. Install or connect the following:
    Power steering lines aside Studs retaining the power steering lines and tighten to 45 ft. lbs. (61 Nm) Nuts retaining the inner cooler tube Inner cooler lower hose to the inner cooler Upper starter bolt by pushing the inner cooler up and out of the way. Tighten to 40 ft. lbs. (54 Nm). Air cleaner box cover Negative battery cable
Jul 03, 2010 | 2002 Chrysler PT Cruiser
I have a Mariner outboard engine which requires the water pump to be removed for repair. The gear shift linkage once disconnected from the oprating lever will not pass through the casing in the engine...
In order to disconnect the gearshift linkage from the gearshift operating handle, a safety clip was rotated about 90 degrees clockwise. Once in this position, if you pull the safety clip towards you, it comes completely out, which then permits the gearshift rod to seperate from the operating lever.
Oct 11, 2008 | 2004 Mercury Mariner
Frozen steering on mariner 75
It sounds like your steering cable is rusted in the eng steering bracket or your cable has gone south (Rust) try some heat to free it up and if that dont work its time for a new cable
Oct 04, 2008 | Simrad 20187423 Teleflex Adapt Lf 3000...
Boating Logo
123 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
