Question about Refrigerators
Water pooling at bottom of fridge....It is an active smart.It is supposed to defrost the freezer periodically and then the water is evaporated .Seems this is not happening....Whats gone wrong
    Scholar:
  • 30 Answers
Unplug the power to the Fridge, take the items out of the freezer. There is a bottom tray that's inside the freezer that has 2 or 4 screws, remove the screws that holds the floor to the freezer and lift it out. You will probably see a sheet of ice on the bottom of the freezer. You may have to take off the back cover which is inside the freezer, it covers the evaporator. Then you will want to defrost the ice, do not use a heat gun it will melt the inside of the freezer. Best way to thaw it is leave the power off and melt it with hot water (not boiling). Either wet vac out the water as it melts or use a hand towel to mop it up. Sometimes a turkey baster will work to squeegee it out. There is a drain hole in the back that you will see as the ice begins to melt. That needs to be clear and the only way to clear it is to cover it with hot water. You will know that it clears and working when you see the water drain out thru the drain hole in the back of the inside of the freezer. By the way the drain drains thru a pipe thru a tray that's on top of your compressor. That's what heats it and makes it evaporate. Be advised that as you see that it is clearing, you can stop dumping water down there as some may get on the floor as the pan may overflow and dump water on the floor. If that happens, just mop up the water from the floor. Now put it back together again and plug it back in and you should have no further problems.
Posted on Oct 04, 2009
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Whirlpool refrigerator is leaking water
If the water is pooling around the bottom of the fridge I would pull the fridge out and pull the panel of the back of the fridge and check to make sure the black plastic drain pan is in place and the white or clear plastic hose coming from the bottom of the fridge is aimed at the drain pan, if they are not then that would be why you have water pooling up under the fridge. Generally the Walter gos into the drain pan after defrost and the heat from the discharge lie of the compresser evaporates the water and it should never overflow. Hope this helps
Sep 08, 2012 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Hi There My Parents have a Fisher & Paykel (E331T) the Freezer is working fine, but the fridge where the dairy products sit don't seem to be freezing at all im not sure if there suppose to be a fan...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Fisher and Paykel Active Smart® E522BR...
Water pooling at the bottom of kenmore fridge
I had a Kenmore fridge - about 20 years old when I replaced it this year. It used to do the exact same thing especially in warm/hot weather. What it is is the water from the freezer defrosting. There should be something on the back near the top, inside the fridge sticking out - a tiny little tray sticking out and it may also be part of supporting one of the shelves, I can't remember. Anyways, water from the defrost pools in there and is supposed to evaporate, but it gets clogged with gunk and the water spills out and runs down the back of the fridge down to the bottom. Get a pipe cleaner or something and poke it into this hole and clean out the pipe to the hole isn't blocked. This is all inside the fridge, not outside, on the back panel outside. That's the best I can do to describe the solution - it's an easy fix you can do yourself. Good luck!
Jan 01, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Periodically, water flows out of the bottom of the freezer door and pools on the floor. The water supply for the icemaker isn't hooked up, so it can't be that.
This is the water coming from your defrost cycle. I'm not sure on this model, but the auto defrost will always generate some water. Some brands use a pan underneath that collects the water and then lets it evaporate, and some put the water in the condenser coil that's under the unit. Yours must have the line that runs from the freezer to the place it's supposed to go unhooked or misrouted. It could also be clogged inside the freezer.
Aug 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
Leak!
Hi as well,
With no other source of water for the leak, this has to be your defrost water, and it does sound like the drain to the evaporator pan is clogged.
The pan will be underneath the unit -- should be a panel you can remove along the bottom edge to access the pan.
If you trace the drain from the bottom of the unit back into the fridge, you can find where the water is supposed to drain into the pan. This is apparently clogged.
May 29, 2009 | Zanussi ZEBF250W Bottom Freezer...
Water leaking from freezer
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle.
May 18, 2009 | Kenmore 64802 Top Freezer Refrigerator
LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
F & P Fridge/Freezer Model N395B freezing under vege bins
While staying with a friend that had this problem we assaulted the fridge. Pulling everything we could apart. After finding this link http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/FRIDGES/517579%20%20Series%20R%20N308R,308XR,325TR,369BR,375TR,395BR,400HR,4.pdf which had a parts list similar to the fridge we had. Pulled out the Defrost timer paragon located next to the compressor. After giving it a good shake it started making ticking sounds again. It appears that it is semi-faulty in our case and had stopped working.
Dec 04, 2008 | Fisher and Paykel Active Smart E522B...
Water in bottom of Roper Refrigerator/Freezer Unit
I have the same problem. I suspect the drain line for the auto defrost is clogged and so the water is dripping down into the fridge. (The water from the auto defrost cycle is supposed to drain into a pan under the fridge where it evaporates over a period of a few days). I have yet to locate the drain line though.
Dec 27, 2007 | Refrigerators
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
