Question about JVC GR-D90U Camcorder
Camcorder will not even turn on... help...
I have a Canon ZR85 camcorder and it will not turn on. Not only will itnot turn on, but it will not run through the powercord either. I tookit to a camera shop and they said the powercord was producing theneeded amount of electricity to charge it. They did not think it wasthe battery either. One day the camcorder was working, would charge,seemed fine... and the next it would not even turn on. I was told itwould be more expensive to send it in and get it repaired than to get anew one... but I dont have the time or money to do either. I'd love tohear if theres a way to fix it, I surely have no idea. Also, is there away to take the camcorder apart and look around inside- maybe cleansomething? I cant figure out how to do that either.
  • 4 more comments
  • soccer4me17 Dec 25, 2007
    how do i take it apart? with a tiny screwdriver?... I tried that and the screws seem to be in pretty well... any tips?
  • LouValle24 Jan 09, 2008
    I have the same exact problem. I've tried using a new battery as well as the power cord but nothing works. It looks like the camera is completely dead. Any advice on how to resolve this, or should I just go out and get a new camera?
  • Anonymous Feb 26, 2008
    Hi my SVP hddv2500 it worked fine earlier today,but wont turn on at all. ive tried takeing out the battery and charging it . but it wont even charge
    530 227-1553 Ed
  • Anonymous Mar 03, 2008
    exact same problem, with a JVC GR-D90U, would the unner fuses be labled simalarly across brands. it wont even eject the miniDV in it/
  • nngau May 22, 2008
    my camcoder DDV C511 also experience the same problem, cannot turn on.
    plug in to USB port but the battery seem like not charging at all.
  • hlum88 May 11, 2010
    Can you send me a diagram or where I should be taking camcorder apart. I needed the location of the fuse. I believe
    I have the same issue since no power and nothing. I check the
    battery with ohm meter and try the a/c all failed. Please,
    send me picture or video if you have any of where and how to
    get to the fuse. THANKS A BUNCH IN ADVANCE. : )
  • 3 Answers
My Canon ZR 600 has exactly the same problem, it wont turn on!!! Ive taken it apart 3 times, i have never seen fuses anywhere on the motherboard?
Posted on Apr 02, 2008
  • 64 Answers
You could take it apart just be careful, when you take a part off put the screws next to the part were they were when they were on there, on the mainboard on the edge there are fuses that have letters on them i cant remember but it might be four fuses that are white with black writing either h or j on them look closely you have to use a ohm meter put it to sound and check each one when you dont get a beeping sound then that could be your problem or a flex might have come loose thats really all you could do.
Posted on Dec 25, 2007
  • derek johnson Dec 26, 2007
    they will come out you just have to apply pressure and make sure the screwdriver you are useing will fit in the screw and not have room to move around it should be snug.
My canon zr85 mini dv camcorder the screen is black when on record even if the side screen is close the eye unit is also black.
It is known problem of ccd imager chip failure in Canon ZR85 camera and ccd imager chip will be replaced to fix the issue.
Local camera repair shop will help you to replace ccd imager chip because solder work is involve.
Thanks.
Jul 21, 2010 | Canon ZR85 Mini DV Digital Camcorder
Zr85 camcorder will not turn no lights no power
Ok, let's try the "easy fixes" first. When this problem happens, it can be a oxidized power switch contact, or oxidized battery contacts on the camera. Clean the battery contacts and the contacts on the camcorder with an eraser gently (they are gold plated). See if the camcorder works now. The next step is only if you're not planning on taking the camcorder apart. There are times when you can give the camcorder a slightly hard "whack" with the palm of your hand, somewhere near the power switch, while the power switch is on, and if the camera works, then you know it's most likely a dirty or oxidized contact inside. See if you can get it working with these methods. If you can't, you will have to disassemble the camcorder or have it serviced. Get an estimate if you get it serviced, since it can be expensive, and you might just opt for a replacement.
Apr 23, 2010 | Canon ZR85 Mini DV Digital Camcorder
My Canon zr85 camcorder turns on, but the screen is black. All the menu stuff shows up, but no picture. When I press play to look at photos, those show up. When I try to shoot images, it's all black.
its look like the opitcal block do not operate
look to canon web site if your cam are not on the recall list at (canon.xxx/support/service)
hope that help you.
Feb 18, 2010 | Canon ZR85 Mini DV Digital Camcorder
Image distorted in both modes canon zr85 camcorder
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced to back in business.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Good luck.
Dec 25, 2008 | Canon ZR85 Mini DV Digital Camcorder
Me screen is black but everything else works
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Good luck.
Canon ZR85
THE COMPARTMENT IS OF TRACK THIS WILL NEED REPAIR SORRY THIS IS ALOT OF MONEY
Feb 02, 2008 | Canon ZR85 Mini DV Digital Camcorder
JVC GR-D90U Camcorder Logo
189 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
