It has been working wonderfully. I went to turn on and it will not project image from my laptop. It says "No Signal". I have went through each source even though it is all hooked up for "COMP2" . . .all say no signal. Both cables are still hooked up, but I unhooked and rehooked just in case they had loosened. Cables are in and nothing is different from when I used it Friday in my classroom. I have to present ot a group of teachers Monday morning and mega hours of work need to be projected on my screen. I am panicking!
  • 630 Answers
Depends on model of laptop but
a) try Fn+F8 (or whatever the Function key that has LCD/CRT on it
b) for xp right click on the desktop>Properties>Output to or go into settings
Posted on Oct 04, 2009
I really need to download driver of pd100
This is an OUTPUT device, it doesn't have a "Driver" It It doesn't receive or give any instructions to or from the PC. It simply uses the Video & Audio, signal supplied from the source, usually a Laptop, and projects that image out.
Mar 23, 2010 | Acer PD100 Multimedia Projector
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
Jul 22, 2008 | Televison & Video
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
Sony lcd projection tv vertical adjustment KF-50E200A
Try changing the settings for the video formats, widescreen, regular, and all that. There are angle mirrors in the back of the tv that direct the projected image on the screen. The mirrors are positioned such that if, says, a piece of a metal bracket or something falls down inside the projection area, it'll fall right against the projection lens and block the image. Open up the back of the tv and follow the light path from the screen backwards to its source and make sure there's no debris in the projection path.
Sep 17, 2009 | Sony KF50E200 TV
No Signal when plugging into laptop
On your laptop you have the ability to toggle the external display on/off/both. On several laptops I see, it is a combo of teh Function Key+F4 (or F5). The key for your laptop (you did not provide type) should be marked with an image of a projection screed or a monitor in a color matching function key; often blue.
With everything connected, press these keys to toggle from Laptop Display Only to Projector Only to Both.
If the problem is not your laptop, then verify the input source that the projector is looking for via it's menus or a button on the remote. Toggle the source if required.
Aug 05, 2009 | Sanyo PLC XU35 Multimedia Projector
My picture won't show after replacing the lamp
Actually that humming sound was not the lamp, the humming sounds come from color wheels when they're going out, and since the color wheel is part of the light engine system and it's not working, that's why you don't have an image, you'll probably ask your self why, since it's not the lamp.. the thing is that the light engine system is componed by lamp, ballast, color wheel and dmd board, so when one of these doesn't work, there will be no image reflected, because they work together
Jul 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Won't project; can't find signal
Make sure that your computer was turned on first (don't ask me why). Then hold down the Fn key while pressing F8. Hope that helps.
Aug 28, 2008 | Dell 3200MP Multimedia Projector
RCA D61W20 Image Turns on and Off, Rat Droppings
im sure that the rodent contamination is the root cause of your problem. but the blueish stain does it look like a smear? if you that is most likely a phosphur burn in the face if the CRT. it cannot be fixed without replacing the CRT. i suggest living with it or putting tv on the side of the curb.
Apr 06, 2008 | RCA D61W20 61" Rear Projection Television
Multi-media projection without image
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past. Hope this helps!
Jun 19, 2007 | InFocus X1 Multimedia Projector
Redish distorted cable picture until I change input source and then go back to cable input
When you say brand new, just how new is it? Your unit could be covered by the warranty. Certainly something worth checking into. If it works fine on all inputs except cable and the cable box has been changed your problem is probably in the digital receiver in the TV. This is something you will need a qualified repair tech to look at but should not be an expensive fix (compared to the cost of the unit). First make sure it is not covered under warranty. Free is still better than having to pay! Good luck.
Jun 27, 2006 | Toshiba 56HM195 56" Projection HDTV
137 people viewed this question
k24674
jasbo
jasbo
