Question about Air Tools & Compressors
I have a toyota voxy 2002 an the a/c light keeps blinking an no cooling its just blows hot air i have checked the a/c gas is full,i have changed the a/c fillter but still it blows hot air,
  • 41 Answers
Open the bonnet,start the engine let it turn on idle, then put the a/c on you will hear a click noise which mean the compressor is being coupled to the engine via the belt.If not check the fuse of the a/c.
Posted on Oct 05, 2009
How many litres of oil for toyota voxy 1.998 engine capacity
How many litres of oil for toyota voxy 2.0 engine Kufa, 4.2L of oil with a filter or 4.0L without filter change.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Toyota VOXY Solving Car Problems
Toyota Noah Voxy 2001 2007 Guide to repair and maintenance Page 4 Catalog...
http://autorepman.com/en/toyota/3422-toyota-noah-voxy-2001-2007-engine-repair-manual.html
Mar 24, 2016 | Toyota Cars & Trucks
My c light is blinking and hot air is blowing. Not sure were to find the A/C Relay and determine what part i need please assist?
What's a "c" light? Does the hot air blow all the time? If you are trying to use A/C and hot air comes out, recharge your A/C system. kits can be purchased at almost any autoparts store
Jun 03, 2011 | 2002 Toyota Camry
The over drive light keeps blinking and AC blowing hot air. I have changed the fuses but they keep blowing
The overdrive light blinking, possibly is indicating a faullt in the trans. Changing the fuse will do nothing for this. Unsure on AC fault.
Oct 10, 2010 | 2001 Ford Windstar
I have a 2002 Toyota Camry. The AC light has just
Either the belt is slipping, or the compressor is bad.
Mar 13, 2010 | 2002 Toyota Camry
1995 Toyota Estima. Air Cond stops cooling periodically
The air conditioning system need to be fill with gas,there is not enough gas in it that why it is doing that,Hope that help you,If there is not enough gas ,when you switch on the ac button it turns the ac compressor and cut off immediately because there is not enough gas.
Jan 17, 2010 | 1995 Toyota Previa
Light on a/c button flashing a/c not cooling
most like the mgt relay in the fuse box under the hood. their is a updated part from toyota.
Jul 18, 2009 | 2003 Toyota Camry
2002 Montana, A/C not cooling. blows hot air.
Sounds like a gas leak..
Most efficient way to handle that is - go to a ac specialist.. They will put more gas in with a die.. Then a week later they will check it again and a floresant light will spot the die - should there be any leaks.. And that way you will know exactly what you are dealing with..
Hope this helps !!
Rate me good ;o)
Jul 10, 2009 | 2000 Pontiac Montana
Ac compressor does not turn on when car has been sitting & it's hot outside. Works fine in the morning.
either the freon charge is about 1/3 low, or the expansion valve needs to be replaced. Freon is getting into the evaporator, but not in great enough volume to cool the air unless it is coming in cool to start with. check your ac charge, and if it is full, then have it emptied, change out the expansion valve, and recharge it
May 14, 2009 | 2002 Jaguar S-Type
Nissan Altima no cool air blowing or hot air blowing
Hi!
It appears we have an Air lock scenario and you will need to perform a system Bleed.
Park the vehicle on level ground, when cold remove coolant filler cap, start engine and leave to idle, turn heater on full and blower to max. When engine reaches operating temperature watch and listen near coolant filler, keep clear as gurgling and hopefully a boil over should occur. Top up with very warm coolant and wait as it may do it again.
Check for heat inside vehicle if warm replace coolant cap but keep an eye on temperature gauge as the ~Air lock may have moved on from heater matrix/core so proceedure needs to be carried out again from COLD.
Please press the Blue button to appraise my FREE Efforts, Thank You!
Paul 'W' U.K
Feb 24, 2009 | 2002 Nissan Altima
Air Tools & Compressors Logo
175 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
