Question about Canon LaserClass 2060P Plain Paper Fax
The Fax machine just gives me a problem on the screen (Ringer off), I don't know what is mean that, please Is it possible to recommend what I do.
  • 68 Answers
It means that your fax will not ring when it receives the fax, but it will receive just fine.If you use this machine as fax only,don't worry about this message,but if you use it as a phone as well and you want it to ring,you will need to go to "menu" and turn the ringer "on"
Posted on Oct 05, 2009
How could the ring volume be adjusted (turned down or off) on a samsung inkjet tel./fax SF-340 series?
Hi!
To adjust the ringer volume, simply press the left/right arrow buttons, the SF340 must be in standby mode.
Every time you push one of those buttons, the ringer volume will be changed down or up. Volume 0 means no ring.
Please let me know if it helped.
Aug 10, 2011 | Samsung SF-340 Plain Paper Inkjet Fax
Lost FAX connection
Can you please describe your problem?
I will be waiting for your reply.
Oct 09, 2008 | HP Lands Phones
I have a panasonic fax machine. It will receive
if this is to every line then you have a bad main board or your ringer waiting period needs to be increased... (meaning the amount of times it rings before pickup...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 10, 2009 | Brother IntelliFAX 4100 Laser Fax
DX-800 beeps with Incomplete Info Code = 720
Error Code 720: Cannot connect to the Pop Server. (Incorrect Pop Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the network Administrator
Regarding the beeping noises. The DX-800 has multiple settings for beeps, rings and the dialing monitor. If it is the latter, press MONITOR button once, then press the DOWN arrow, until silenced. Some ringer/beep settings are under Fax Parameters, some are in a special SERVICE MODE.
let us know if you can isolate which one and we can help turn it off. At least now you know what the 720 code means.
Good Luck!
Nov 10, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Turn off fax ringer - turn on phone ringer Laserclass 2060P
Hi
You can set it for manual mode.
Or set it for fax only but set the incomming ring count to more than 8 times that will give you time to answer a call before it go to fax.
Jan 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
Panasonic KXFHD331 something simple the ringer volume was adjusted and somehow it got messed up and now wont receive I dont know what to change
ringer volume can bi adjusted with volume key or with navigator kex by pressing up and down.if fax is not receiving just check fax receive mode .put iton fax only mode.by mian jee
Dec 02, 2008 | Office Equipment & Supplies
How do you turn off the ringer
On printer control panel, select setup, then select #4 (basic fax setup), then #6 (ring & beep volume). Select OK, then press either the left or right arrow until "OFF" appears - then press OK. This will turn off the ringer for the fax machine and will also silence the keypad tones.
Jul 10, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Incoming Phone Ringer
After months of trying to solve this problem I finally figured out that the machine was set to phone/fax mode instead of fax only. If you have a dedicated fax line you can set to FAX ONLY MODE. In FAX ONLY MODE you can control whether or not the machine rings when it receives a fax call. You do this by selecting Data Registration, Press Set and use the up and down arrows to select 4. RX Settings. Press Set and use the up and down arrows to display the item you want to set or change and turn the ringer OFF. Press Set.
Mar 26, 2008 | Canon LaserClass 2050 Plain Paper Fax
Canon LaserClass 2060P Plain Paper Fax Logo
old marine
old marine
