Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Using the router
I have internet service through cox cable but would like to use my actiontec wireless router how can i do this
  • 4,281 Answers
First connect your router to computer then access your router as following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page .
Then set WAN settings as your internet service provider settings.
Enable DHCP.
Go to wireless enable wireless.
SEt wep security if you want secure wi fi.Add WEP code it is your password to connect internet so only who know the password are connect to your wi fi .
Then save settings and restart router.
Let me know if you need more assistance.
Thanks.
Posted on Oct 04, 2009
How do I get my EnGenius ESR-9752 router to work with my Actiontec GT701 modem? I have a desk top computer using XP. I just bought a lap top with wireless capabilites. I want to run this system through the...
1. connect yellow cable from Actiontec to the internet port (labeled internet)
2. Power cycle the engenius router.
3. login to the Engenius and verify the status. You should an IP Address from the ISP (Internet Service Provider). If not then you will have to verify the IP address from the router.
4.Make sure the laptop the see the wireless connection.
5.Verify the "ESSID" if your router and connect.
Apr 25, 2010 | Computers & Internet
I have cable internet through Charter. Want to use GT704WG router
Unfortunately, this router is only able to be used with DSL. When you are using cable internet this router will be rendered useless with your new service. If you call customer service for Charter they do offer Home Networking that provides you with a wireless router for a small monthly fee or if you are looking for a lower cost one time charge you might check with them as well and see if they provide a "refurbished" wireless router or check on ebay for some good deals....
Good luck...
Dec 31, 2009 | Actiontec GT704WG Wireless Router...
Can a actiontec gateway wireless DSL router be connected to a comcast cable modem?I have an old DSL wireless router (gateway), can I use this as my wireless router with comcast cable internet, or do i need...
You could do it, but it's a bit of a pain in the ***** and probably not worth the hassle.
Actiontec DSL gateway was not designed to act as a "proper" router and therefore you won't be able to make it act like one permanently (well, unless there's a hacked firmware out there somewhere ;).
Of course, since it runs linux, you can telnet into it and manually set up the ip addresses on both wireless/wired interfaces and the necessary route between them. It will then work as a wireless access point for your comcast cable modem, but any changes will be lost every time you reboot the actiontec.
I've done it in the past with similar setup but quickly got tired of having to console the actiontec to add the ips and routes every time it crashed -and eventually got a proper wireless router.
So-it can be done, just not easily.
Have fun,
Raf
Nov 08, 2009 | Actiontec (GT701WG) Wireless Router
My Actiontec wireless router is not transmitting.
hi bob,,.
     Ur prob s coz of incomplete installation of ur drivers,,. install the recomended drivers and access,.  it will,,.
Mar 16, 2009 | Actiontec Computers & Internet
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
CAN I USE AN ACTIONTEC G704WG IN THE FOLLOWING CONFIGURATION: 1. CONNECT THE G704WG TO MY PC, ETHERNET TO ETHERNET 2. COMMUNICATE WITH MY NEARBY HP LAPTOP WIERELESSLY, BACK AND FORTH. THANKS, WAYNE...
yes that is possible connect your PC to the actiontec using the lan cable. set your wireless network, then have you other hp join the network.
you can share folders, and printers, and also have your HP connect to the internet through that actiontec.
Jan 06, 2009 | Actiontec GT704WG Wireless Router...
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Actiontec GT701-WG won't operate wirelessly
In looking on the internet the unit is a DSL gateway. Trying to use it on cable internet is not a real good way to set up your network because I believe the router is waiting for a DSL sync before the services turn on. I would spend the money and pick up a Linksys or Netgear G router, there around $50.
Jun 01, 2008 | Actiontec (GT704WG) Router
INSTALLING ACTIONTEC WIRELESS ROUTER/MODEM
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | Actiontec GT704WG Wireless Router...
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
204 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
