Question about Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 won't power on
The ac adaptor LED light is on. Tested the end of the ac adaptor that plugs into the laptop, and it has power. The computer has no signs of any kind of power. The LED lights that indicate battery or power on the outside of the unit are not on. Any suggestions?
    Novelist:
  • 188 Answers
These are prone to broken power jacks that short out components on the mainboard. My shop saaw a lot of these come in dead like this and sometimes we could get them going again with a lot of mainboard work, but it seems they keep breaking.
I would save your money for another laptop considering the lousy reliability record these models have.
Posted on Dec 26, 2007
Compaq Presario x1000 with no battery won't start off AC
Battery is needed to complete circuit. Too bad you didn't have the old one.
http://www.ebay.com/itm/Battery-For-HP-Pavilion-ZT3300-ZT3200-ZT3100-ZT3000-Compaq-Presario-X1000-X1200-/150853086051?pt=Laptop_Batteries&hash=item231f8b6b63
Not advertising, it is just an example.
Still doesn't work after Battery installed, post back in a Comment.
Suggest do not be so quick to toss it away.
Regards,
joecoolvette
Dec 19, 2012 | Compaq Presario X1000 Notebook
Need ac adapter/power cord
You can get a replacement power cord for this laptop from any elctronic or computer store near you like Besbuy or Radioshack, of you can order it online from this sites.
http://www.nextag.com/compaq-presario-700-power-cord/products-html
http://www.bizrate.com/laptop-accessories/compaq-presario-700/
Apr 29, 2010 | Compaq Presario 700 470024-192 Notebook
Will not work with ac power adaptor but does with
Did you wiggle it a bit when plugged in? You can't tell from looking on the outside if the plug is fine because it goes bad inside where it is soldered. This is a very common problem, and have fixed many laptops with the same problem. All of them had a bad solder connection inside. Did you dtermine the plug was fine by plugging another ac adapter to your laptop or you just checked it visually? Hit me up I will solve this one for you.
Aug 12, 2009 | Compaq Presario 700 470024-192 Notebook
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
Receiving Charge will not turn on
Take out the battery and only have the ac adaptor hooked up to the laptop and then try to turn it on.
If that doesn't work, then the motherboard is faulty. Probably a short in the motherboard but the whole thing would need to be replaced.
Also make sure your using the correct adaptor as well.
Feb 10, 2009 | HP Compaq Presario V2000 Notebook
No Power, Cannot open
contact ur dealer..its hardware problem!
Dec 27, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Laptop wont start ... ( Presario 700 )
chk your ac adapter bro .. i think its not working
Aug 27, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Compaq Presario 1680 Notebook shows no power in window when plugged in.
Take the battery out disconnect the AC adaptor Press and hold the power button about 7 seconds. Put the battery in and connect to AC adaptor press and release the power button. If it caused by static-component lockup, issue will be resolved. If still there is no activity including no power light check the AC Adaptor if its working
Good Luck
Dec 30, 2007 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
134 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
