Question about Microsoft Xbox 360 Console
No video or sound
I just plugged in my x-box and I have no video or sound. I hooked up my hd tv cables and I have the switch in the hd tv position. All of the green lights on front of x-box are working. Can you help?
Okay tried different cable and different TV pushed cables in TV all the way and pushed connector into back of x-box in and still nothing? thx for the help
Posted on Dec 23, 2007
  • 152 Answers
Try another cable. If that doesn't work, then try it on another TV. If that doesn't work, then make sure the cables are in all the way.
Posted on Dec 22, 2007
I have an older onkyo 1994 or 1995 receiver dolby pro logic with the amplifier and 6 disk changer wnd the system is clear as could be in cd mode. my problem is Ihave my xbox hooked up to the tv with hdmi...
No no no!
# 1. You need to connect all your components to your TV via an HDMI cable. For true HD and digital sound this is needed. Your TV (if its an HD TV) should have 3 or 4 HDMI inputs. So your Xbox/PS3 should be connected via HDMI cable. Your HD sat or cable box should also be connected with an HDMI cable. Same for your Blu Ray player.
#2. Now that your components are connect in a way which will enable you to see their media in either 720p, 1080i or 1080p your ready to get the Digital sound to your speakers. On the back of your TV you should (again on most all HD tv's) have a digital audio (optical) out. You need to purchase a digital (optical) audio cable and plug one end into your tv's digital audio out jack. Then plug the other end into your audio receivers digital audio in jack. You may have to go into your receivers menu to select or enable the digital/optical input. Then you should be rocking and rolling with true digital DTS, Pro Logic, Pro Logic 2 in either 5.1 or 7.1...
Think of your TV as the hub. Connect all the components with HDMI cables. And then your TV to your receiver with a digital/optical cable. It's that simple.
Never never use the red and white cables for audio. They were designed for 2 channel stereo sound. They won't deliver 5.1 or 7.1 digital sound.
Also... Don't ever hook up any component using the old "yellow" video cable if you want picture quality better than 480i resolution. They won't do HD period.
Here is a list of the popular video cables and they highest resolution.
Yellow video cables - 480i resolution
S video (super video) cable - 480p
Component video cables (red/blue/green) - up to 720p
HIgh definition multimedia interface HDMI - up to 1080p (full HD) and digital sound.
Hope this helps...
Nov 03, 2012 | Onkyo Audio Players & Recorders
I want to connect my cable box to my newly bought toshiba plasma
Is your cable box HD? It would be best for your tv. You can hook up a couple of ways depending on your receiver and tv in/out capabilities. You will always get best picture if you go directly from your cable box out to tv in. You should have capabilty to go HDMI out and perhaps Component out on your cable box. If you can't get hd receiver from cable company. Anyway, if you use HDMI, hook to HDMI out on receiver to HDMI in on tv. HDMI provides audio and video. You can also go componenet(red, blue, green) out from recevier to in on tv. I personally feel component gives you better picture but , doesn't carry audio. For that you need to get audio using either digital optical or, composite cables. You may have to set your HD on receiver through cable boxes menu. The last option is using composite cables(last choice, poorest picture and sound) yellow(video) and red, white(audio)
Apr 04, 2011 | Audio Players & Recorders
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
I'm having trouble hooking up Toshiba DVD, HD cable box and TV.
first is this DVD recorder? its not okay plug the wires from DVD to tv (left / right and video -digital in or av1 in) cable box is connected to tv (red/blue/green) tv should be on component (source)...to view dvd switch to av1 or digtal1.......if this is a recorder get a coaxial cable and connect from cable box out to DVD in (the TV setup stays the same as above) DVD set up should be on CATV/ch 3..........the out connection is the same as a reg player (see above)
Aug 28, 2010 | Toshiba Televison & Video
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
Hook up sony blu ray
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways.
1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
Jan 03, 2010 | JVC AV-48WP30 48" Rear Projection...
Hi 4 yo x box 360 turns on fine with normal
If you are using the component cables, assuming it's the same cables that came with it 4 years ago, there is a little switch on the part that hooks up to the Xbox360. The two options are HD and Regular. Try moviing that switch to the other position. Also try another tv, friends or family if you don't have another one. Also, if you have a friend with a 360, swap out the component cables as these have been known to go bad after a while.
Nov 20, 2009 | Microsoft Xbox 360 Console
Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
When connecting XBOX live to LG flatscreen there is no video only
There should be a switch on the cable that says HDTV/TV if you are using component connections, make sure that the switch is set to HDTV.
May 12, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
