Question about Power Acoustik MOFO-15 Car Subwoofer
I have no sound to my woofers they were working just fine then stoped?? what is the problem
  • 22 Answers
Check the fuses on the inline and the amp(s). Then check the power and ground for solid connections and the remote if needed. By process of elimination you should be able to find the fault in the wiring. If all checks on the above the problem would have to lye in the RCA's or speaker wiring. Also be sure to have the proper resistance in your subs (ie.2ohm,4ohm) and that the amp can handle that resistance.
Posted on Oct 04, 2009
No sound from woofer behringer truth monitor b2031
first check woofer (end wire problem )
remove woofer from circuit
test with 1.5v battery cell touch parallel woofer lead neck
if disturbance sound come from woofer
woofer is ok
Apr 29, 2014 | Behringer Truth B2031 Other Dj Equipment
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
What is the proper wiring diagram for the car stereo system in a 1999 Mercedes Benz Clk 320
i put a new stereo in was working fine ater about 20 min speakers stoped working but the sub-woofer is still working
Jan 03, 2010 | 1999 Mercedes-Benz CLK
If i increase the sub woofer volume the voice distorts and gives a buzzing sound. it works fine on low volume
Your sub woofer is not mean for voice sound...check that you have connected the systen up properly and that you have put the sub woofer into its wn connection..if it is in the right connection the woofer could be blown.also try decrease the midrange hurts on the woofer
Jan 03, 2010 | Audio Players & Recorders
Could a ground stop your woofer from working?
First check the speaker wire from the amp to the sub, see if it's connected right. Second check the rca cables that goes from your amp to the back of the deck. I f both wires are still connected fine try to replace the rca cables. If it still doesn't work the rear out put at the back of your deck, where the rca's are connected are bad. FYI deck is bad.
Nov 29, 2008 | Jl Audio 12W3 Car Subwoofer
JVC TH-M606
You need to take apart tthe sub woofer and check the connection to bass speaker for continuity. It sounds like an internal broken connection to speaker on sub woofer unit.
Aug 12, 2008 | JVC TH-M606 System
Sound problem with Creature II Woofer.
just increase subwoofer level located at the front. If it doesn't work then replace your woofer if it is in warranty period because it migth be due to internal electronic components failure.
Jun 17, 2008 | JBL CREATURE II Computer Speakers
MACKIE SWA1801--Sound quality is not same
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
How do i fix my sub woofer?
U just remove subwoofer and clean it with a piece of cloth, then fix it ur computer it will wirk. If not, pls make service it.
Nov 02, 2006 | Dell HK395 Computer Speakers
Power Acoustik MOFO-15 Car Subwoofer Logo
49 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
