Question about Microsoft SideWinder Force Feedback 2 Joystick
Microsoft Force Feedback 2 joystick
Gentlemen:
How can have my 5+ year old joystick repaired? It seems that MS no longer sells these sticks and makes it very hard to find an authorized repair location.
I have 2 of the older Force Feedback Pro also of the serial port types. Thank You
John Wyatt
  • 1 more comment
  • Anonymous Apr 15, 2008
    When plugging-in the AC power cord there is no "power feedback" and there is no indication that the PC recognizes there is a componant plugged in either.
    Checked internally and the Fuse (encapsulated type) is good; the AC is moving from the input to the transformer and there is 24vDC out to the Control board. So, I suspect the control board has failed. Where can I purchase a new control board.
  • Grazz1 Nov 08, 2008
    I have same problem just wondering if you managed to fix yours i'm curretly searching for replacment parts , also you may have after sometime get problems with trigger switches iv'e been doing some reserch and found this > http://forums.ubi.com/eve/forums/a/tpc/f... maybe helpfull to you in the future , I'll post back here if i find a source for parts .
    Grazz .
  • Mick Carmichael Nov 28, 2008
    There is no Feedback, when powered, nor any indication, by Windows, that it sees a USB device plugged-in. 1120v AC is applied internally, as well as the 24v is on the Main pcb.
    Is there anyone who knows the availability of the Main pcb as a replacement part?
I have the same problem - have lost all stick forces (everything else works fine) and the Forces self test that can be run from the original CD software says there is no electrical power. Have changed the fuse etc. but problem remains. I think something inside the device hardware is bust. Like you I cannot find anything on the Internet as to how or where the device can be repaired!
Simon Kuczera
Posted on Jan 01, 2008
Have microsoft sidewinder force feedback pro with 9 pin connecter.need usb adapter
You have the old game port connector. I have one of those too and researched it and even bought one of the adapters. What I found is that the adapters will generally work EXCEPT if your unit has force feedback. The force feedback versions of the MS sticks uses a special protocol that the adapters can't handle. I haven't looked recently, but if you look for an adapter make sure it says it will support force feedback (most will say they don't). In my case I just bought a new joystick.
Dec 27, 2012 | Microsoft SideWinder Force Feedback Pro...
Sidewinder force feed back joysticks
i have 3 sticks that i want rid of some need new micro switches fitted , i have the switches all you need do is fit the switches i think i have an instuction somewhere on how to pull a sidewinder 2 apart
May 16, 2012 | Microsoft SideWinder Force Feedback 2...
Cyborg evo force joystick seem to chatter with or without force effects on or off in fsx and il2-46, i have remove all drivers and re-installed several time with no improvement,even disarmerd stick in...
You might clean out the registry of any left over values. Try it on another machine if it still does it, its something mechanical inside maybe stuck. I suppose its out of warranty? You cant fly with those stickers anyways if that's what you do. Scourer the junk shops for an old MS Sidewinder, they are still the best stickes ever made.
Jun 18, 2017 | Saitek CYBORG EVO FORCE Joystick
I need drivers for microsoft sidewinder force feedback pro joystick that works with windows 7 64bit
buy a joystick that will work with win7, because the MS Sidewinder has no driver, and MS has no vested interest in developing one...
Jan 18, 2010 | Microsoft SideWinder Force Feedback Pro...
No force feedback only with Flight Sim. 2004
O-the sweet feel of a Microsoft Sidewinder Force Feedback lets see if I can be of some help. there could be any number of things going on but I'm going to give this a try. have you checked the settings in Flight Simulator 2004 seems to me that I remember a check box that said disable force feedback make sure that is unchecked. also in the settings for your controller there is a box that says enable force feedback make sure that is checked. then make sure if you are using a firewall like zone alarm you are in gaming mode because this used to give me major headaches with my system to the point I had to detach from the internet and shut down my firewall to play my games. if this doesn't work you may have to reinstall the drivers for the sidewinder this is the last easy option and it should repair any broke links and reset itself into your system. Please let me know how this helped if you need more Ideas just contact me.
Jul 24, 2009 | Microsoft SideWinder Force Feedback 2...
Lack of control with force feedback 2 on flight simm.X
i had a similar problem and the cause was i wasn't getting power from the wall socket
Feb 21, 2009 | Microsoft SideWinder Force Feedback 2...
Need a port for my MS force feedback pro
Just get yourself a new soundcard with a gameport on board. Disable your MoBO soundcard if you have one and instal the new one. Creative is probably the safest option. Update the drivers and off you go. Don't forget to add the joystick, the drivers are supplied in XP.
Jan 15, 2009 | Microsoft SideWinder Force Feedback Pro...
The Software
I have same stick, that same software wont work with xp or vista depending on what game you have you should be able to set up in input settings for the game , there was a patch at one time that someone made up you mite want to try here and do a search > http://forums.ubi.com/eve/ubb.x?a=frm&s=400102&f=49310655
Grazz.
May 18, 2008 | Microsoft SideWinder Force Feedback 2...
Microsoft's Sidewinder Force Feedback Pro Driver
Sorry to report that there is no driver for this stick that will allow the feedback to work with Win XP. I wanted to cry when I first found this out. I've been searching since the mid 90's for a work around for this. We can send a man to the moon and back on less than 1 meg of ram. But someone can not get this stick to work properly with Win XP?
That REALLY SUCKS!!!
Dec 28, 2007 | Microsoft SideWinder Force Feedback Pro...
Microsoft SideWinder Force Feedback 2 Joystick Logo
736 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
