New dvd player does not show color in picture
I hooked my new, relatively cheap DVD player (made by BBK, a Chinese brand primarily for Russian market) up to my new flat-screen Samsung. The DVD works and I see a clear picture. but there is no color, and I cannot figure out the problem. do I need a new cord? any thoughts? thank you!
  • 189 Answers
HELLO
If it's made for the USSR market then it's possible the video is set to SECAM whereas you need NTSC. It may have a PAL or NTSC setting so try that.
Your TV should be set to AUTO to pick up the video (they normally are multi-standard these days). You may have another setting on your TV called "PAL 60".
As I'm not that familiar with NTSC equipment I can only guess (we are on PAL in the UK), but I very much hope I have given you some idea of what to look for and do! (:-)
ALL THE BEST!
Posted on Oct 04, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
How do I fix video player? Only shows colored lines but you can still hear audio.
Is this a DVD player? If so, on the back of the player, check that the plugs are all pushed all the way on. They shouldn't wiggle or anything. If there is wiggling, see if it affects the picture when you move it around. If it does, get a new player. They are cheap these days.
If that doesn't work, check the connection that the DVD player is hooked up to (TV or Receiver). Following the same steps as above.
If the connections are all good. Next, try doing a cleaning on the laser. You will need a cd or dvd cleaning kit from the dollar store. Just follow the instructions.
If after cleaning it you still have that problem. Try the player on another TV and see if you get the same problem. If you do, the player is most likely bad..again cheap to replace.
If the problem is gone, then it may be the TV connections or something similar on that original TV.
Hope that helps.
Nov 04, 2015 | Miscellaneous
Does not have 3 color connections. Can you hook up a DVD player?
you must use the "Composite" video output (the single yellow plug, with the red/white for audio of course) of the DVD player. Tube TVs rarely have "Component" connections because they are primarily used for 480P and above resolutions, which tubers can't produce. If your TV and DVD player have "S-Video" connections, use them for the best possible picture.
Dec 27, 2010 | GE 25GT270 TV
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
May 27, 2009 | Sony Televison & Video
What DVD video formats are supported by BBK? I need to copy video files from my PC to show on TV. PC shows these videos in Windows Media Player. The videos were taken by Cannon camera in "MOV" file format.
Supported Video formats:
VCD,SVCD,AVI
DIVX,JPG
As you see no support for mov files
You'll have to convert these mov files to avi...
Go to http://www.radgametools.com/bnkdown.htm and
download the Rad Videotools.This little program helps you convert
all your mov files to avi. Burn the avi files on a cd and you should be able to play them on your dvdplayer..
Jay
May 20, 2009 | BBK Electronics DV965 DVD Player
Needed English User manual of Model BBK9916.
posted the russian version of the manual for your DVD Recorder in HTML.
go to this address.  http://translate.google.com/translate_t?hl=en#
enter this address. use exact case.   www.jrgimaging.biz/DW9916S.htm
Select Russian from the Pulldown and hit translate.
Some of it is translated.
I have a PDF of the manual but it is in Russian. If you can find a PDF translator it will probably work better than google translate.
Mar 25, 2009 | Televison & Video
DVD Player is not tracking the picture
DVD players are dirt cheap now. Just buy a new one, and if your TV has HDMI, get one that will hook up that way.
Aug 06, 2017 | Lasonic DVD-8090 Portable DVD Player...
DVD player will not show in color.
could be loose or damaged SVideo cable or cable getting interferance from other equipment. try moving cable around and see if color comes back.
Sep 16, 2007 | kawasaki SVP500 Multi-disc DVD Player
Televison & Video Logo
279 people viewed this question
Top Televison & Video Experts
