Question about Vacuums
Hey where does the belt go?
Can you help me figure out how to replace the belt on this Hoover
  • jdb3 Feb 25, 2009
    2 belts ? i have only seen the one for the brush roll. when i run the vacuum it smells of ... burning rubber.
  • 1,673 Answers
You didn't give your model #, but most Hoover's, if you turn the vac ove, take out the screws to remove the plate covering the brush roll and belt. The number of the belt is on the belt, unless it is worn off, it is also on the metal tag that the model number is on. Put belt around the motor shaft or pulley, then around the brush roll and stretch it to put brush roll in place. If this is a wind tunnel, it has 2 belts, one for brush roll, which is a V belt, and a flat belt for the motor to the pulley.
Posted on Jan 15, 2008
How do i replace the vacuum belt for a hoover upright, bagged, 18.0
go to and put in the model Follow directions in the manuelUsually only requires a screwdriver
Feb 28, 2012 | Hoover Vacuums
How to replace geared belt on Hoover Savvy U8171
Tom, This one is tricky. First get the belt on the geared motor pully, and then insert the roller through it. You will have to roll the brush toward the body of the vac to have enough room. Patience is the best on this model.
Jan 10, 2010 | Hoover U8171-900 / U8172-900 / U8173-900 /...
No suction on my vacuum. Hoover Tempo
try to clean between the roller and the tube to the hose
May 05, 2009 | Vacuums
Lost instructions,need to change belt
The customer operation manual can be downloaded from the hoover web site
the bottom cover comes off with 4 screws. install the belt on the motor, then roller, stretch to install roller into cavity. replace cover.
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Upright...OLD vacuum, broken belt
The rod must be your brush roll. it should just pull out, Have you removed the cover over the brush roll? When you do get the brush roll out, turnb the ends and make sure they turn freely, if nit, replace it also.
Sep 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Belt Replacement in Hoover Savvy
go to thehooverstore site. find your machine and they'll have exploded diagrams for your machine - your should be able to tell how to replace the belt.
Sep 01, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 28, 2007 | Hoover 5416-900 WindTunnel Bagged Upright...
Vacuums Logo
138 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
